I am trying to program my digital potentiometer ad5241 with flowcodeV4 but I can't get it to work. my SDA and SCL are each connected to 10K resistor.
This is my program.
MI2C_init
MI2C_start
MI2C_Transmit_Byte 0b01011110 (this is my adress byte for the AD 5241 the first 5 MSB byte are the adress the 2 next are AD1 and AD0 they must be 1 caus they are connected to VDD and the last bit is READ or WRITE so i made it 0 to write)
MI2C_Transmit_Byte 0b00000000 (instruction_Byte wich i do not use , i sellect RDAC1 to use register 1 for a single potentiometer.)
MI2C_Transmit_Byte 0b11111111 (this is the data byte ,it sets the resister value to full scale)
