ds18b20:CRC Function instead of CRC table
FFT
PostPosted: Fri Nov 26, 2010 11:25 am     Reply with quote
Hi All,
I'm trying to replace the crc table with a function that calculates 8-bit crc for ds18b20 sensor because of limited ROM space, but no chance.
I'm using exactly that code in:
http://www.ccsinfo.com/forum/viewtopic.php?p=126649#126649
I've found this function:
//calc_CRC - INTERNAL FUNCTION
//Purpose:    To calculate an 8-bit CRC based on a polynomial and the series
//            of data bytes
//Note:       Polynomial used x^8 + x^5 + x^4 + 1 = 10001100
//Inputs:     A pointer to an array of the data bytes and an int saying how many
//            bytes there are in the data array
//Outputs:    An int8 which is the calculated CRC
int8 ds18b20_calc_CRC(int8* data, int8 bytes)
   #define CRC_POLY      0x8C
   int8 shift_register = 0, i, datab, bits;
   for(i = 0; i < bytes; ++i)
      datab = *(data + i);
      for(bits = 0; bits < 8; ++bits)
         if(bit_test((shift_register ^ datab), 0))
            shift_register = shift_register >> 1;
            shift_register ^= CRC_POLY;
         datab = datab >> 1;
   return shift_register;
} //calc_CRC
Just I've changed the row in ds1820_read() function:
if (scratch[8] == dowcrc)
to
if (scratch[8] == ds18b20_calc_CRC(scratch[0], 7)) // Calculate a 8-bit crc for all 7 scratch bytes
In the linked code, but it does not work.
Also I've tried it as:
// One wire crc
int8 ow_crc(int8 x)
//   dowcrc = dscrc_table[dowcrc^x];
   dowcrc = ds18b20_calc_CRC(x,8);
   return dowcrc;
As said in : http://www.ccsinfo.com/forum/viewtopic.php?t=41878
As another way I've found this link:
http://www.phanderson.com/PIC/16C84/crc.html
The C function on link should call for every byte I think, I tried some variants to import it into my code but could not make it works too...
I need help to replace crc table with a function for reducing rom usage.
Best regards
PostPosted: Sat Nov 27, 2010 7:50 pm     Reply with quote
This is basically a Google question, where you search for code.
There are ds18b20 CRC routines on this forum:
http://www.ccsinfo.com/forum/viewtopic.php?t=40106&start=14
