PIC 18Fxxxx 12 Bit A/D support
PostPosted: Thu Nov 25, 2010 8:58 pm     Reply with quote
Just had to use a 12 bit internal PIC A/D on an upgrade-a 16F886 design.
Problem is - I can't make the compiler hand me over a proper 12bit conversion without working around the intrinsic A/D functions!
BTW-
#device ADC=12 does NOTHING
I did solve it but there is no syntax in the main compiler that I can make do ANYTHING except return an 8 BIT low order byte and nothing else.
Yes, solved, but its ugly.
Can anybody tell me why the compiler seems not to handle this part right?
version 4.085 compiler
#include <18f2523.h>
#Fuses RC_IO,NOPROTECT
#Fuses BROWNOUT,NOWDT,BORV43
#Fuses PUT,NOCPD,STVREN,NODEBUG
#Fuses NOLVP,NOWRT,NOWRTD,NOIESO,NOFCMEN
#Fuses NOPBADEN,CCP2C1,NOWRTC,NOWRTB,EBTR
#Fuses NOEBTR,NOEBTRB,NOCPB,NOLPT1OSC,NOMCLR,NOXINST
// done in the INIT section already
// using 8 mhz int RC clock no multiplier
     //                                                    A/D setup
     setup_adc( ADC_TAD_MUL_8|ADC_CLOCK_INTERNAL ); // 4 usec
     setup_adc_ports( AN0_TO_AN4|VSS_VDD);   //  R3
     set_adc_channel( 3 ); //  continuous read DC signal detector  0-5v
     unsigned int16 adcout;
void adcll(void){   // get a 12 bit adc reading
   unsigned int8 cpr=255;
   #byte adhi = 0xFC4
   #byte adlo = 0xFC3
   read_adc(ADC_START_ONLY);
   do {--cpr; } while (!adc_done() && cpr);
   if (!cpr) baddie(88);  // an error message reporter
   else delay_cycles(4);
   adcout = adlo + (adhi*256);
PostPosted: Thu Nov 25, 2010 10:42 pm     Reply with quote
Try a more simple program:
#include <18F2523.h>
#device adc=16
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#byte ADCON2 = getenv("SFR:ADCON2")
#bit ADFM = ADCON2.7
#define right_justify_adc() ADFM = 1
int16 result;
setup_adc_ports(AN0_TO_AN4 | VSS_VDD);
setup_adc(ADC_CLOCK_DIV_4);
right_justify_adc();
set_adc_channel(3);
delay_us(20);
   result = read_adc();
   printf("%lx \n\r", result);
Also, the output impedance of your analog voltage source must be no
more than 2.5K ohms.
code flips
PostPosted: Fri Nov 26, 2010 7:59 am     Reply with quote
new code to be tried later today
i am much more at home with hardware -oh for about 35 years -
the A/D port is fed from the output of a buffer op amp.
input Z not involved
the conversions results are dead-on accurate with the code shown -
but using CCS defaults -ONLY the low 8bits are passed back
more later
update
PostPosted: Fri Nov 26, 2010 8:15 am     Reply with quote
Sorry I also already had the code below in my original init zone.
I was already doing what you suggested - but forgot to extract and show that bit of code.
I was using -
#bit ADFM 0xFC0.7 // adcon2 on the 18fxxxx
then globally
ADFM=1;
STILL the intrinsic A/D functions return ONLY the low 8 bits of the 12 bit conversion - into the 16 bit variable. If I use the CCS built-in call - 8 bits
with the direct register reading code - 12 good bits.
I think its bugs in the compiler version I'm using. Now more than ever.
And the fix I am using works fine - so I chalk it up to another bump in CCS device handling.
