18F14K22 very inaccurate ADC
doctorprox
PostPosted: Tue Nov 09, 2010 3:20 pm     Reply with quote
Hi all.
I have tried everything to get the ADC on this chip working correctly but it just wont.
It seems to be around 20% out, ie. 2.5v in reads in on the ADC as about 3.1v, and fluctuates all over the place (actual 10bit ADC readings from 610-650 sent by RS232 and also measured externally via PWM).
Power supply is stable at 5.01v
I have tried running off a crystal aswell, makes no difference.
Any help would be MUCH appreciated.
#include <18F14K22.h>
#FUSES PLLEN
#FUSES NOMCLR
#FUSES INTRC_IO
#device adc=10
#use delay(internal=64000000)
#use fast_io (ALL)
#use rs232(uart1, baud=38400)
long adcval;
long count;
  set_TRIS_A(0b11111111);
  set_TRIS_B(0b01111111);
  set_TRIS_C(0b01011111);
   setup_adc(ADC_CLOCK_DIV_64);
   setup_adc_ports(sAN3);
   set_adc_channel(3);
   delay_us(20);
   setup_ccp1(CCP_PWM);
   setup_timer_2(T2_DIV_BY_1, 255, 1);
   count = 0;
astart:
count+=1;
If (count==1000){
   output_toggle(pin_c7);
   count=0;
adcval = read_adc();
if (count==500)
   printf("%Lu \r\n",adcval);
set_pwm1_duty(adcval);
GoTo astart;
doctorprox
PostPosted: Tue Nov 09, 2010 3:45 pm     Reply with quote
Seems my multimeter was affecting the input voltage somehow. Changed multimeter and it appears to now be fluctuating around +-2%.
Not ideal since i may aswell be using 8bit in that case. Could this be the internal osc?
PostPosted: Tue Nov 09, 2010 4:00 pm     Reply with quote
What device is driving the AN3 input pin ? What is the output impedance
of this device (in ohms) ? The 18F14K22 data sheet says:
16.3 A/D Acquisition Requirements
The maximum recommended impedance for analog
sources is 10 Kohms.
Also, try reducing the PIC frequency to 4 MHz. Change the ADC divisor
to ADC_CLOCK_DIV_4 for this test. See if it affects the result.
PostPosted: Tue Nov 09, 2010 4:11 pm     Reply with quote
And (of course), though the power supply may 'appear' stable, it rarely is. Scopes will not tend to show really high frequency noise. Voltmeters won't respond to this. It is 'rare' to get better than perhaps 7-8bit real accuracy using the power supply as Vref (only by ensuring all digital circuits are 'static' during the sampling, and sleeping the processor)...
Gabriel
PostPosted: Tue Nov 09, 2010 4:30 pm     Reply with quote
@Ttelmah, what if the power supply is a battery?
CCS PCM 5.078 & CCS PCH 5.093
doctorprox
PostPosted: Tue Nov 09, 2010 4:35 pm     Reply with quote
The power supply is actually a PC PSU, probably not the best of supplies.
Anyhow, the input to the ADC was a 1Mohm pot. I have replaced this with 100ohms and the results now seem spot on. Cheers PCM.
