dave.t Guest
exclusive oring of port pin |
Posted: Wed Apr 30, 2003 9:41 am |
Hi all
I have just started to use the 12f629 chip and have written a simple led flasher program which uses the overflow on timer 1 to generate an interrupt - the isr then toggles the led.
In my isr routine I initially used:
led=led^1;
(led being gp0)
I have used this with previous chips (16f877 etc.)for test purposes with no problems but it will not work with the 12f629. If I replace the statement with:
toggle=toggle^1;
led=toggle; (toggle is a short)
it works ok.
Any thoughts?
Thanks very much
Dave
___________________________
Original Post ID: 14082 |
Re: exclusiv oring of port pin |
Posted: Wed Apr 30, 2003 1:13 pm |
:=Hi all
:=I have just started to use the 12f629 chip and have written a simple led flasher program which uses the overflow on timer 1 to generate an interrupt - the isr then toggles the led.
:=In my isr routine I initially used:
:= led=led^1;
:=(led being gp0)
The following sample program worked OK. It was compiled
with PCM vs. 3.148.
I myself wouldn't toggle a pin in this manner. You're
depending upon properly reading the value of the pin. It may
work in a particular case, or even in most cases, but you're
taking a hardware risk. There could be capacitance on the
pin, or you could run into the RMW problem if your PIC is
running at high speed. I mean, it's OK for a hobbiest, but
I wouldn't do it for production.
I'm not saying anything is wrong with it in this particular
case. What I'm saying is that I don't make little exceptions
when I'm writing code. I always go for what's the most safe
and the most clean.
So I would use the other method you described, with a separate
variable that holds the LED state. Toggle the variable, then
write the variable out to the pin.
But here's the working code with your original method.
<PRE>
#include <12F629.h>
#fuses INTRC, NOWDT, NOPROTECT, NOMCLR
#use delay(clock = 4000000)
<BR>
#bit LED = 5.2
<BR>
main()
set_tris_a(0x00);
<BR>
LED = 0;
<BR>
LED = LED^1;
LED = LED^1;
<BR>
</PRE>
Original Post ID: 14093 |
j_purbrick Guest
Posted: Wed Apr 30, 2003 1:55 pm |
:= led=led^1;
:=(led being gp0)
:=Dave
Assuming the 629 works the same as the 877 and you're running the LED by connecting it in series with a resistor between the pin and Vdd or Vss, then I think you can get around problems with the actual pin output (involving XOR operations, etc) by working with the corresponding TRIS bit instead. But this wouldn't work if you have to drive logic off the pin.
Original Post ID: 14096 |
