Problem with PLL clock setting
steveo
PostPosted: Wed Oct 27, 2010 8:15 pm     Reply with quote
Hi, I am new to Pic C language and am having trouble setting PLL x 4 clock settings. I am using PCWHD compiler V 4.109 and 18F8722. I am using the Flex_Lcd.c driver and have changed the settings to suit my dev. board.
This works.
#include <18F8722.H>
#fuses   HS,NOLVP,NOWDT,NOPROTECT,NOSTVREN
#define LED PIN_H0
#use delay(clock = 10000000)
#include "flex_lcd.c"
   while(1) {
lcd_init();  // Always call this first.
Delay_ms(1000);
lcd_putc("\fHello World\n");
lcd_putc("A new start");
output_high(LED);
Delay_ms(1000);
output_low(LED);
//Delay_ms(1000);
but this does not.
#fuses   H4,NOLVP,NOWDT,NOPROTECT,NOSTVREN
#define LED PIN_H0
#use delay(clock = 40000000)
   while(1) {
Delay_ms(1000);
output_high(LED);
Delay_ms(1000);
output_low(LED);
//Delay_ms(1000);
I have tried a number of variations found on an earlier post but no luck. Any help would be great to get me started.
Thanks.
steveo
PostPosted: Wed Oct 27, 2010 11:07 pm     Reply with quote
I think I have it sorted out. Seems to be some timing issues with my LCD module a look at the data sheet and some changes has fixed it.
Regards
