hi.. i am using pic16F877a how can i generate internal clock..
i want to know what short comes can be faced with internal clock generation..
thanks _________________ ...
Posted: Wed Oct 27, 2010 3:58 am
You can't.
Read the chip's data sheet. Any mention of an internal RC oscillator?.
To use the internal oscillator, you need to select a chip that has one...
SherpaDoug
Posted: Wed Oct 27, 2010 4:35 am
If you do use a chip with an internal oscillator be sure to read the datasheet about oscillator accuracy over voltage and temperature changes. Usually they are not quite good enough for serial comms over all conditions. _________________ The search for better is endless. Instead simply find very good and get the job done.
