Sid2286
Hardware Issue |
Posted: Wed Oct 27, 2010 4:40 am |
I have 5 seven segments connected where i'm displaying the analog inputs.
the circuit works fine on ICD2.
however, when I'm placing it on breadboard, m getting display but its all fluctuating. It is not at all constant :(
Please help me
Regards,
Sid |
Joined: 01 Jul 2010 Posts: 9162 Location: Greensville,Ontario
Posted: Wed Oct 27, 2010 5:02 am |
Without schematic or code it's hard to tell but first guess is power supply capacity. I would suggest a minimum of 2 amps at a rock stable 5 volts,with appropriate bypass caps both on the supply and near the PIC on the breadboard. |
Posted: Wed Oct 27, 2010 5:13 am |
Other thing - grounds.
The ICD, will give you a nice solid ground and will be connecting back to the PC ground. 'Breadboard', won't.
Make sure you don't have 'daisy chained' grounds with analog circuitry connecting along a ground path where currents for the displays are being drawn.
