PicUSB and RF 433Mhz problem
matheuslps
PostPosted: Wed Oct 27, 2010 3:40 pm     Reply with quote
Hi people. I have another problem here.
I did this project PicUSB by J1M: http://www.ccsinfo.com/forum/viewtopic.php?t=24207&postdays=0&postorder=asc&start=0
It is working very fine. I modified the program in Visual C# 2010 and it is working like a charm. I can read temperature with LM35 and show on screen of a PC. OK! :D I am using a 18F4550.
But I like to comunicate with another 18F4550 with RF 433Mhz. I bought one module but the communication over RS232 is not working.
I tried with one wire to simulate the RF module and didint worked.
I do not know how to calculate the baud rate. Embarassed
My cristal is 12Mhz. But with the fuses that I am usign, I put 48Mhz to the clock.
I am using CCS 4.057. With Proteus it worked.
My codes:
Transmitter:
#include <18F4550.h>
#device adc=10
#define WireTX PIN_C6 // <--------- C 6
#define WireRX PIN_C7
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL3,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rs232(baud=2400,xmit=WireTX , rcv=WireRX ,ERRORS , STREAM=COM_A )
#define USB_HID_DEVICE     FALSE             //deshabilitamos el uso de las directivas HID
#define USB_EP1_TX_ENABLE  USB_ENABLE_BULK   //turn on EP1(EndPoint1) for IN bulk/interrupt transfers
#define USB_EP1_RX_ENABLE  USB_ENABLE_BULK   //turn on EP1(EndPoint1) for OUT bulk/interrupt transfers
#define USB_EP1_TX_SIZE    2                 //size to allocate for the tx endpoint 1 buffer
#define USB_EP1_RX_SIZE    5                 //size to allocate for the rx endpoint 1 buffer
#include <pic18_usb.h>     //Microchip PIC18Fxx5x Hardware layer for CCS's PIC USB driver
#include <PicUSB.h>         //Configuración del USB y los descriptores para este dispositivo
#include <usb.c>           //handles usb setup tokens and get descriptor reports
#define LED_OK           PIN_B6
#define LED_FAIL         PIN_B7
#define LED_ON           output_high
#define LED_OFF          output_low
int periodo;
int ciclo1=0;
int ciclo2=0;
int ciclo3=0;
#define modo      recibe[0]
#define param1    recibe[1]
#define param2    recibe[2]
#define param3    recibe[3]
#define param4    recibe[4]
#define resultado envia[0]
#define barra     send[0]
#define status    send2[0]
A interrupção:
#int_timer1
void TIMER1_isr (void)
   set_timer1(65480);                             //Preload do timer1
Testes para ciclo = 0:
   if (ciclo1 == 0)
      output_low (PIN_B0);
   if (ciclo2 == 0)
      output_low (PIN_B1);
   if (ciclo3 == 0)
   output_low (PIN_B2);
Já que o ciclo é diferente de 0:
   if (periodo <255)
      If (periodo < ciclo1)
         output_high (PIN_B0);
       If (periodo < ciclo2)
         output_high (PIN_B1);
       If (periodo < ciclo3)
         output_high (PIN_B2);
   else if (periodo == 255)
      periodo=0;
   periodo++;
void main(void) {
   int8 recibe[5];                  //declaramos variables
   int8 envia[2];
   int8 send[1];
   int8 send2[1];
   int16 adc=0;
   LED_OFF(LED_OK);                   //encendemos led rojo
   LED_ON(LED_FAIL);
   usb_init();                      //inicializamos el USB
   setup_adc_ports(AN0);         //Configura canais analógico
   setup_adc(ADC_CLOCK_INTERNAL);    //De acordo com relógio interno.
   usb_task();                      //habilita periferico usb e interrupciones
   usb_wait_for_enumeration();      //esperamos hasta que el PicUSB sea configurado por el host
   LED_OFF(LED_FAIL);
   LED_ON(LED_OK);                    //encendemos led verde
   while (TRUE)
      if(usb_enumerated())          //si el PicUSB está configurado
         if (usb_kbhit(1))          //si el endpoint de salida contiene datos del host
            usb_get_packet(1, recibe, 5); //cojemos el paquete de tamaño 3bytes del EP1 y almacenamos en recibe
            if (modo == 0) // Modo_Suma
               resultado = param1 + param2;  //hacemos la suma
               usb_put_packet(1, envia, 2, USB_DTS_TOGGLE); //enviamos el paquete de tamaño 1byte del EP1 al PC
            if (modo == 1) // Modo_Carro
               if (param1 == 0)
                  fputc('U',COM_A);
                  delay_ms(20);
               if (param1 == 1)
                  fputc('R',COM_A);
                  delay_ms(20);
               if (param1 == 2)
                  fputc('D',COM_A);
                  delay_ms(20);
               if (param1 == 3)
                  fputc('L',COM_A);
                  delay_ms(20);
               if (param1 == 4)
                  fputc ('S');
            if (modo == 2) // Envio da Temperatura
               set_adc_channel(0);           //Habilitación canal0
               delay_us(20);
               adc = read_adc();
               barra=((5*adc*100)/1024);
               usb_put_packet(1, send, 1, USB_DTS_TOGGLE); //enviamos el paquete de tamaño 1byte del EP1 al PC
            if (modo == 3) //Modo PWM
               if (param1 == 0)  //pwm desativado, pinos em nível baixo
                  SETUP_TIMER_1 (T1_DISABLED);       //Configurar timer1 para clock iterno/8
               if (param1 == 1)  //pwm ativado
                  SETUP_TIMER_1 (T1_INTERNAL|T1_DIV_BY_2);       //Configurar timer1 para clock iterno/8
                  enable_interrupts (INT_TIMER1);                //Habilitar Interrupções
                  enable_interrupts (global);
                  ciclo1=param2;
                  ciclo2=param3;
                  ciclo3=param4;
            if (modo == 4)
               status=1;
               usb_put_packet(1, send2, 1, USB_DTS_TOGGLE); //enviamos el paquete de tamaño 1byte del EP1 al PC
Receiver:
#include <18f4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,PLL3,CPUDIV1,VREGEN
#use delay (clock = 48000000)
#define WireRX PIN_C7 //<-----
#use rs232(baud=2400, xmit=WireTX, rcv=WireRX, ERRORS, STREAM=COM_A)
unsigned int8 data;
int flag=0;
//#include <lcd.c>
#define LED1 PIN_B0
#int_rda
   void rd_isr(void)
      disable_interrupts(INT_RDA);           // Disable Serial Recieve Interrupt
      disable_interrupts(GLOBAL);            // Disable Global Interrupts
      data= fgetc(COM_A);
      if(data=='U')
         flag=1;
      if(data=='R')
         flag=2;
      if(data=='D')
         flag=3;
      if(data=='L')
         flag=4;
      if(data=='S')
         flag=5;
      enable_interrupts(INT_RDA);
   //lcd_init();
   enable_interrupts(global);
   enable_interrupts(int_rda);
   output_high (PIN_D2);
   for(;;)
     Switch (flag)
         Case 1:
            //lcd_putc ("\fU");
            output_toggle(LED1);
            delay_ms (100);
         Case 2:
            //lcd_putc ("\fR");
            delay_ms (100);
         Case 3:
            //lcd_putc ("\fD");
            delay_ms (100);
         Case 4:
            //lcd_putc ("\fL");
            delay_ms (100);
         Case 5:
            //lcd_putc ("\fS");
            output_low(LED1);
            delay_ms (100);
        flag=0;
thanks for any reply
MatheusLPS from Brazil
bye
