I am using picf877.
How I can make pin_b[i] varies from pin_b0 to pin_b7?
I want to make 8 switches on PORTB to control 8 LEDs on PORTC
Is there easier way to make this instead of loops?
Last question
Is there a function to test if any pin in portB got 1 signal from out?
I mean:
check(PORTB)
If 1 comes to pin_b3 for example, check(portb) should return pin_b3.
Thanks and sorry for my bad english.
Posted: Sat Oct 16, 2010 9:18 pm
You could create an array of 8 bytes, and initialize it to the list of pin
names that you want. The pin names (constants) are given in the
16F877.h file. Example:
http://www.ccsinfo.com/forum/viewtopic.php?t=29344
scottc
Posted: Sun Oct 17, 2010 2:11 am
There are a number of ways to do what you want. You could capture
port b, and test it to display the contents on port c. You would want to
pull up each pin to VCC using a 47k resistor.
I believe this might do the trick for you.
byte switches; //variable to hold switch data
switches = input_b(); //switches connected to port b
output_c (switches); // Port C display's contents of port B
