Reversing the order of bits in a variable
Bill Legge
PostPosted: Mon Oct 18, 2010 10:00 pm     Reply with quote
I'm a few weeks into learning C and think that I'm making a mountain out of a molehill?
The aim is to reverse the order of bits in a variable. I've done it by:
   int32 x = 0x0; // variable
   int32 y = 0x0; // variable with bits reversed
   int8  z = 0x0; // bit counter
    for(z=0;z<=31;z++)
         if(bit_test(x,z)==1) bit_set(y,31-z);
         else bit_clear(y,31-z);
I think there is a better/simpler way to do this. Any advice please.
Regards Bill Legge
Denmark in West Australia
'Where the forest meets the sea'
PostPosted: Mon Oct 18, 2010 10:49 pm     Reply with quote
Use the forum's search page. Run it on the Code Library forum.
