Function using array of float data does not work
rigomm
PostPosted: Sun Oct 17, 2010 11:09 pm     Reply with quote
Hi everybody!
I´m trying to do a very simple program using floating data.
The program only has to save the data of one array into another variable and return.
Obviously, this is just a test program.
The problem is that when I call the function, the value in the array is always zero.
Below the code:
//               main.c
#include  "30f3012.h"                                //DEVICE
#device adc=12
//*****************CHANGED INITAL dsPIC parameter to work at higher speed using the PLL
#FUSES HS2_PLL8//The xtal freq is divided by 2 and multiplied by 8 (maximum using 20MHz xtal)
#FUSES NOWDT // NO Watch Dog Timer
#FUSES PR_PLL //Primary Oscillator
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#use delay(clock=80000000)// 20MHz/2*8=80MHz=80000000
#use rs232(baud=115200, xmit=PIN_B4, rcv=PIN_B5)            //To transmite result over Bluetooth
//DEFINE===================================================
#define LED     PIN_D0
//●For test-----------------------------------------------------------------
float bandpass(float r[1][2],float r2[1][2]);
//*****MAIN*****//
   printf ("start");
   float step = 0;
   float x[1][2]={1,2};
   float y[1][2]={3,4};
    float a[1][2]={0,0};
//      step= x[0][1];
//      printf("  step  %f \n \r", step); //display
      step = bandpass(x,y);
      a[0][1]=step+y[0][1] ;
        printf("  Value  %f \n \r", a[0][1]); //display
   }//*1
float bandpass(float x1[1][2],float y1[1][2])
   float z =0;  //初期化
   z = x1[0][1];//2を代入
        printf("  Z  %f \n \r", z); //display
        printf("  x  %d \n \r", x1[0][1]); //display
   return(z);
In this example, the program should display 2 for the value of Z or X(0,1) but instead of that, it appear a zero. and actually, the function returns zeros as value of z.
What is wrong.
I did exactly the same program but using integers and it works smoothly.
It seem as when I call the function it does not take the value of the parameters.
Can anybody give a clue? please!
