bkamen
[SOLVED] CCS places string handler outside of #ORG range |
Posted: Mon Oct 18, 2010 10:29 am |
So I've been playing with the CCS bootloader and I noticed that the printf handler in the bootloader code is being placed OUTSIDE the range the bootloader is supposed to live in.
If I define the application to take up all the space that isn't bootloader space, I get a compiler error that says there's no space available (when there is). If I back off the application zone definition, those items are inserted right after the "end" of application space and the compile succeeds.
It's obvious what it is as the "CALL PSTRINGC_115200_31764_31765" points to:
FC00 0009 TBLRD*+ (label is @PSTRINGC_115200_31764_31765)
FC02 52F5 MOVF 0xff5, F, ACCESS
FC04 E00D BZ 0xfc20
FC06 CFF6 MOVFF 0xff6, 0x4f
FC0A CFF7 MOVFF 0xff7, 0x50
FC0E 50F5 MOVF 0xff5, W, ACCESS
FC10 A8A4 BTFSS 0xfa4, 0x4, ACCESS
FC12 D7FE BRA 0xfc10
FC14 6EA9 MOVWF 0xfa9, ACCESS
FC16 C04F MOVFF 0x4f, 0xff6
FC1A C050 MOVFF 0x50, 0xff7
FC1E D7F0 BRA 0xfc00
FC20 0C00 RETLW 0
I also noticed #USE RS232 with the ERRORS argument places the error handler out in the same space (after the pp) before the string handler when there's PLENTY of room in the bootloader's defined range.
Has anyone else noticed this and found a way to control it? (I've already emailed CCS about it as well) _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D
Posted: Mon Oct 18, 2010 10:42 am |
Because there may be various misunderstandings about the exact way, you are defining the said code locations, I would prefer to see an example, and also know about the compiler type and version. |
bkamen
Posted: Mon Oct 18, 2010 10:51 am |
FvM wrote: | Because there may be various misunderstandings about the exact way, you are defining the said code locations, I would prefer to see an example, and also know about the compiler type and version. |
Shoot. I thought I typed the version.
PCH 4.112 on PIC18F26J11
I'll have to write an example. (since posting the bootloader would be a no-no).
Let me get that in a bit.
bkamen
Posted: Mon Oct 18, 2010 2:15 pm |
Nevermind... I talked with Mark and it's just a matter of the #ORG placement.
In front of the #USE RS232, it does what I'd expect, BEHIND the #USE RS232 it was doing what I didn't expect.
Some of the pre-processor commands are really kinda location specific when it comes to some other pre-processor commands.
-Ben
EDIT: As it turns out though, strings (like printf("HELLO!\r\n"); ) are actually reserved in space OUTSIDE a controlling #ORG for a given function. I'm still looking into this with CCS.
So in the bootloader where I have #ORG 0x100 (where 0x100, 0x7FF) is the previously defined range, inside a function a PRINTF() and it's constant string can be found OUTSIDE 0x100-0x7FF someplace. Ouch.)
UPDATE: Ok, so where I was going wrong was the use of default with #ORG. I was following the CCS example which had a final #ORG default at the end of the bootloader.c followed by a #int_global.
I thought the #int_global needed the #org for whatever reason. But being the last #org WITH a DEFAULT seen by the compiler, it told the compiler that anyplace outside my bootloader region was ok to place constants and code which was undesired.
So I removed the #org, #int_global still went to 0x0008/18 and other stuff of concern got properly stuffed into the loader defined segment as desired.
Cheers -- Ben _________________ Dazed and confused? I don't think so. Just "plain lost" will do. :D |
