Blinking Led Wizard
santiniuk
Blinking Led Wizard
PostPosted: Mon Oct 11, 2010 3:40 pm     Reply with quote
Hi. I'm using PCWH 4.112 and have tried it on my desk pc and laptop.
I'm finding something weird. On the desk pc when I run the pic wizard, on the general screen I have a section at the bottom with the option of Example program then a Blinking led and Pin dropdown.
This does not show on the laptop.
Same versions etc so confused ?
Any reason for not showing on the laptop ?
Humberto
PostPosted: Tue Oct 12, 2010 12:19 pm     Reply with quote
This could happen if you made an update over an old version installed. Try uninstalling completely and then install again only the last version.
Regards.
santiniuk
PostPosted: Wed Oct 13, 2010 6:24 am     Reply with quote
Just want to say thanks.
That is a strange issue. When looking at the about box and version panel shows that both machines had latest version numbers installed.
An uninstall and re-install has fixed the problem !
I now see the blinking led option on the wizard screens.
Cheers.
