Problem using LCD.c
siphorob
View user's profile Send private message Send e-mail AIM Address
Problem using LCD.c
PostPosted: Wed Oct 13, 2010 12:46 am     Reply with quote
I'm using a 16x2 lcd RB0 - RB3 are used for data,
RB4 is unused, ENABLE is connected to RB5, RS is connected to RB6 and rw is connected to RB7.
The LCD does not display anything..
There is the source code.
#include <16F877A.h>
// Un-comment the following define to use port B
#define use_portb_lcd TRUE
struct lcd_pin_map {                 // This structure is overlayed
           int     data : 4;         // be pin B0.
         BOOLEAN unused;           // low order up.  ENABLE will
         BOOLEAN enable;           // on to an I/O port to gain
           BOOLEAN rs;               // access to the LCD pins.
           BOOLEAN rw;               // The bits are allocated from
        } lcd;
#locate lcd = getenv("sfr:PORTB")
#define set_tris_lcd(x) set_tris_b(x)
#if defined use_portb_lcd
   #locate lcd = getenv("sfr:PORTB")    // This puts the entire structure over the port
   #ifdef __pch__
    #locate lcd = 0xf81
   #else
    #locate lcd = 6
#else
   //#locate lcd = getenv("sfr:PORTD")    // This puts the entire structure over the port
   #ifdef __pch__
    #locate lcd = 0xf83
   #else
    #locate lcd = 8
   #define set_tris_lcd(x) set_tris_d(x)
int main() {
   lcd_putc("Yippee I made my LCD work!");
   return 0;
Edited to remove segment of lcd.c
Reason: Forum Rule 10
10. Don't post the CCS example code or drivers, or ask for such code and drivers.
Forum rules -
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
-- Forum Moderator
Regards,
Brandon
Wayne_
PostPosted: Wed Oct 13, 2010 2:03 am     Reply with quote
The compiler automatically puts a sleep instruction as the last instruction of main. You need to put an infinate loop in to stop the pic from going to sleep.
Also remove the return as main has nowhere to return to, Unless you are using some sort of booter.
This has been discussed many times on here:-
int main() {
  while(true) {}
siphorob
PostPosted: Wed Oct 13, 2010 3:45 am     Reply with quote
Thanks Smile ,
I'll test the code.
Regards,
Brandon
siphorob
PostPosted: Wed Oct 13, 2010 10:40 am     Reply with quote
Confused
The piece of code still did not work.
Regards,
Brandon
PostPosted: Wed Oct 13, 2010 11:24 am     Reply with quote
Try using the Flex lcd driver. It's much easier to get it working:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
Make sure the contrast pin on your LCD (Vo) has about 0.4 volts on it.
This contrast voltage will allow you to see characters on the LCD.
siphorob
PostPosted: Wed Oct 13, 2010 1:08 pm     Reply with quote
Thank you, thank you.
The is the best fourm ever Very Happy
Regards,
Brandon
