CAN bus Filters problem
mattmac24
PostPosted: Wed Sep 29, 2010 11:56 am     Reply with quote
Hi guys, Ive been reading up a fair bit on this problem and I know there are alot of posts about this but I am still having trouble getting my can bus to work. I am using 2 PIC18F4685, each connected to a MCP2551 and MAX232 chip. I have 120ohm terminating resistors in place on the can bus.
I am trying to accept only messages for 1 can id (for now). Using can standard addressing. When I set it to accept all it seems to work fine.
Here is my code (modified from PCM programmer's test program for can).
#include <18F4585.h>
#fuses HS, NOPROTECT, PUT, BROWNOUT, NOWDT, NOLVP
#use delay(clock=20M)
#include <can-18xxx8.c>
int32 BOARD1_ID = 0x224; //548
int32 BOARD2_ID = 0x223; //547
//SET_TRIS_D(0x00); //  ---not needed but why does this give errors???--
// Uncomment this line to compile code for Board #1.
// Comment it out to compile for Board #2.
#define BOARD1   1
struct rx_stat rxstat;
int32 rx_id;
int32 tx_id;
int8 rx_len;
int8 buffer[8];
can_init();
#ifdef BOARD1   // For Board #1
set_id_to_accept(BOARD2_ID);
      buffer[0] = getc();   // Wait for a character
         // Transmit it to board #2.
        can_putd(BOARD2_ID, buffer, 1, 1, 0, 0);
         buffer[0] = 0;   // Clear the buffer byte
       // Wait for the char to be echoed back.
      while(!can_kbhit())
            //output_high(PIN_D0);
            output_high(PIN_D1);
               //output_low(PIN_D0);
               output_low(PIN_D1);
              if(can_getd(rx_id, buffer, rx_len, rxstat))
                     if(rx_id == BOARD1_ID)  // Is it for this board ?
                             putc(buffer[0]);  // If so, display the char
                           output_low(PIN_D0);
#else  // For Board #2
set_id_to_accept(BOARD1_ID);
   //   output_high(PIN_D1);
         output_low(PIN_D0);
   //   output_low(PIN_D1);
         if(can_kbhit())  // Message available
               output_low(PIN_D1);
               output_low(PIN_D1);
               // If so, get the message.
                     if(rx_id == BOARD2_ID)  // Is it for this board ?
                           // If so, echo back the character.
                           can_putd(BOARD1_ID, buffer, 1, 1, 0, 0);
The can_set_accept_id is one I made. It is inside can-18xxx8.c
void set_id_to_accept(int32 id) {
   can_set_mode(CAN_OP_CONFIG);
   can_set_id(RX0MASK, 0x7FF, 0);  //set mask 0..exact match - 0x7FF all 11 bits must match
   can_set_id(RX0FILTER0, id, 0);  //set filter 0 of mask 0
   can_set_id(RX0FILTER1, id, 0);  //set filter 1 of mask 0
   can_set_id(RX1MASK, 0x7FF, 0);  //set mask 1 ..see above
   can_set_id(RX1FILTER2, id, 0);  //set filter 0 of mask 1
   can_set_id(RX1FILTER3, id, 0);  //set filter 1 of mask 1
   can_set_id(RX1FILTER4, id, 0);  //set filter 2 of mask 1
   can_set_id(RX1FILTER5, id, 0);  //set filter 3 of mask 1
   can_set_mode(CAN_OP_NORMAL);
The led's are only for me testing this as for some reason I can not transmit serial output. I can see my messages being sent on an oscilloscope from the output of the max232 but they never show up on my pc (sending from pc to pic works fine however).
Any help to get this working would be greatly appreciated or any general comments about my code would be good too as I am still new to all this.
Thanks for your help,
Matt
PostPosted: Wed Sep 29, 2010 4:18 pm     Reply with quote
What compiler version do you have ? The fact that it's sticking TRIS
statements out in space suggests that it's an old version. The version
is listed at the top of the .LST file, which will be in your project directory.
mattmac24
PostPosted: Thu Sep 30, 2010 5:32 am     Reply with quote
Hi, thanks for your reply.
I added that line in manually when I wanted to be sure I could put leds in places. It gave me errors which I couldn't really make much sense of. Where should that line go if I wanted to set the pin inputs/outputs? At the moment it is commented out anyway now and the leds work as expected. I think I'm running version 4.093 of the compiler but there was no .LST file I could see.
PostPosted: Thu Sep 30, 2010 3:13 pm     Reply with quote
Lines of code go inside functions, not in isolated areas by themselves.
That line is not needed anyway. The CCS compiler sets the TRIS for you
when you call the output_low() and output_high() functions.
mattmac24
PostPosted: Thu Sep 30, 2010 8:15 pm     Reply with quote
Yes now I can see that it is pretty obvious why that was giving errors. Good to know that it is all taken care of automatically thou.
Can you offer any tips with the rest of the code as to why my can filters are not working as expected? I am still having the same problems.
Thanks,
Matt
PostPosted: Sun Oct 03, 2010 3:58 pm     Reply with quote
Do you have these swapped ?
mattmac24
PostPosted: Sat Oct 09, 2010 8:43 pm     Reply with quote
Yea that was it Embarassed
Sorry, I guess I just made a stupid mistake and couldn't pick it up. Thanks for all your help! I'm obviously very new to this type of thing.
