eoinoc
SD Card Questions |
Posted: Wed Oct 13, 2010 2:26 am |
Hi there ,
I have a few questions with regard to writing to SD and FAT16 formatting.
I need to build a device which is capable of logging RF data to an SD card such as RSSI message length type etc. Generally the data doesnt need to stored vey frequently, maybe every few minutes, but there will be some scenarios where i will need to log 100's of bytes per second.
My question is how long does it take for the built in CCS FAT16 formatting functions to append data to a text file on the SD card. Could somebody give me a figure here in us per byte or something ?
Also how much program memory will I need on my PIC to include these FAT16 libraries ?
Also would it be worth using a PIC24F because of its 16bit architecture to speed up the FAT16 formatting ? I aim to run at 8MIPS be it on an 18F or a 24F. |
asmallri
Posted: Wed Oct 13, 2010 3:17 am |
I do not know the performance envelope of the CCS driver but here are general answers.
With careful application development, it is possible to record data rates of 100K bytes per second. Achieving data rates of 10K bytes per second is straight forward.
The size of the code naturally varies depending on the functions actually called as the CCS compiler only includes code for functions actually called. For my drivers I allow around 12K to 16K of program memory. The amount of RAM required depends on the number of simultaneous open files and whether you are concerned about RAM size or maximum performance.
Code: | The LITE mode shares a single 512 byte read/write buffer between the file system and all open files and is capable of supporting hundreds of files open concurrently. For high performance applications that require two or more files open concurrently, the standard mode is recommended
RAM requirements: Standard Lite
File System overhead 560 560
Per File Overhead 540 38 |
Generally byte wide operations are used in the file system and as such there is not a lot of difference in the performance between a 16 bit processor and an 8 bit processor. When you factor into account the actual performance is really limited by the SPI speed so if both PICs operated the SPI bus at the same speed the performance difference would be minor. However a PIC24 is capable of running the SPI bus at twice the speed of a PIC18 processor for the same clock speed.
As mentioned, RAM is key consideration. I generally recommend to customers planning to developed FAT based applications on the PIC18F family to go for PICs with 3900 bytes of RAM, such as the PIC18F4620. It is easier with the PIC24 as most variants offer significantly more than their PIC18F counterparts. _________________ Regards, Andrew
