Problem 24FJ256GB110 and 25LC256
microlo75
PostPosted: Wed Oct 06, 2010 10:34 am     Reply with quote
I have this problem using a 24FJ256GB110 and 25LC256
#ifndef EEPROM_SELECT
#define EEPROM_SELECT PIN_D12
#define EEPROM_CLK    PIN_G6
#define EEPROM_DI     PIN_G8
#define EEPROM_DO     PIN_G7
#define EEPROM_ADDRESS long int
#define EEPROM_SIZE    262144
void init_ext_eeprom() {
   output_high(EEPROM_SELECT);
   output_low(EEPROM_DI);
   output_low(EEPROM_CLK);
BOOLEAN ext_eeprom_ready() {
   BYTE cmd[1], i, data;
   cmd[0] = 0x05;                  //rdsr opcode
   output_low(EEPROM_SELECT);
   for(i=1; i<=8; ++i) {
      output_bit(EEPROM_DI, shift_left(cmd,1,0));
      output_high(EEPROM_CLK);   //data latches
      output_low(EEPROM_CLK);      //back to idle
        shift_left(&data,1,input(EEPROM_DO));
   return !bit_test(data, 0);
void write_ext_eeprom(EEPROM_ADDRESS address, BYTE data) {
   BYTE cmd[4];
   BYTE i;
   BYTE wren;
   wren=0x06;
   cmd[0]=data;
   cmd[1]=address;
   cmd[2]=(address>>8);
   cmd[3]=0x02;
   // Wait until the eeprom is done with a previous write
   while(!ext_eeprom_ready());
   for(i=0; i<8; ++i)
      output_bit(EEPROM_DI, shift_left(&wren,1,0));
   for(i=0; i<32; ++i)
      output_bit(EEPROM_DI, shift_left(cmd,4,0));
BYTE read_ext_eeprom(EEPROM_ADDRESS address) {
   BYTE cmd[3];
   BYTE i,data;
   cmd[0]=address;
   cmd[1]=(address>>8);
   cmd[2]=0x03;
   for(i=0; i<24; ++i)
      output_bit(EEPROM_DI, shift_left(cmd,3,0));
   for(i=0; i<8; ++i)
   return(data);
the program works, but sometimes there is an error in reading the EEPROM
how is it possible?
example:
about 10 times this routine 2-3 times only the right data!!
for(slot=0;slot<1000;slot++)
    usb_cdc_putc(read_ext_eeprom(slot));
    delay_us(300);
a few bytes are wrong!!!
I could not use the SPI ...
Embarassed
Thanks to all
PostPosted: Wed Oct 06, 2010 12:20 pm     Reply with quote
I don't have the PCD compiler, so I can't help very much.
But, my suggestion is to prove that the SPI interface is the problem.
Change your test to the following:
usb_cdc_putc((int8)slot);
delay_us(300);
This should display incrementing numbers from 0 to 255, several times.
If it fails, the problem is the CDC interface. If it works, the problem may
be in the SPI interface.
microlo75
Solved
PostPosted: Fri Oct 08, 2010 11:25 pm     Reply with quote
With SPI work !!!!!
Thanks for reply
bye
