I want to know that is it possible to increment Timers (as counter) externally via pins? Without using any "external interrupt pin then in ISR increment timer".
I want directly via PINs ??
I am using PIC16F877A , 18F4550.
Tell me what should I do ??
andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Posted: Wed Oct 06, 2010 9:47 pm
I think you should read the respective data sheets and see which timers are connected to external pins. From memory, Timer 0 and 1 of both those chips each support external inputs, and Timer 1 additionally supports async counting (i.e. while asleep). The data sheet will tell you for sure. _________________ Andrew
