How to save float numbers in EEPROM
richi-d
PostPosted: Fri Oct 08, 2010 6:20 am     Reply with quote
I need to store a float number in EEPROM. I know it´s a 32bit value, so I need 4 Byte. But how can I do that? Casting the value to int32 will cause that for example 1.2345 (float) is 1 (int32) !
The Bit numbers in float are this:
00011001 00000100 00011110 01111111
This is what I tried, butt not working:
   STEIGUNG_M[0] =  1.2345;
   DUMMY_5 = STEIGUNG_M[0];
   DUMMY_0 = DUMMY_5 & 0x000000FF;
   write_eeprom(6 , DUMMY_0);
   delay_ms(5);
   DUMMY_4 = DUMMY_5 & 0x0000FF00;
   DUMMY_1 = DUMMY_4 >> 8;
   write_eeprom(7 , DUMMY_1);
   delay_ms(5);
   DUMMY_4 = DUMMY_5 & 0x00FF0000;
   DUMMY_2 = DUMMY_4 >> 16;
   write_eeprom(8 , DUMMY_2);
   delay_ms(5);
   DUMMY_4 = DUMMY_5 & 0xFF000000;
   DUMMY_3 = DUMMY_4 >> 24;
   write_eeprom(9 , DUMMY_3);
   delay_ms(5);
   delay_ms(5);
PostPosted: Fri Oct 08, 2010 6:30 am     Reply with quote
CCS manual page 311: 'How do I write variables to EEPROM that are not a byte?'
richi-d
PostPosted: Fri Oct 08, 2010 7:01 am     Reply with quote
Thank you, I tried this:
void WRITE_FLOAT_EEPROM( long int n, float data)
   int p;
   for (p = 0; p < 4 ; p++)
      write_eeprom(p + n, *(((int 8 *)&data) + p));
float READ_FLOAT_EEPROM( long int n)
   int q;
   float data;
   for (q = 0; q < 4; q++)
      *(((int 8 *)&data) + q) = read_eeprom(q + n);
   return(data);
But always this error:
*** Error 58 "D:\Controller_Software\Universal_Switch+Kap\Kalibrierung.c" Line 6(29,30): Expecting a close paren
I want to use it in a PIC16F688
Wayne_
PostPosted: Fri Oct 08, 2010 7:17 am     Reply with quote
As you have not posted all the code (or have you ?) it is hard to tell where line6 is, I assume it is:-
Try removing the space between (int 8 *) so you have (int8 *)
Also the same applies to the next function.
richi-d
PostPosted: Fri Oct 08, 2010 7:20 am     Reply with quote
Thank you so much! It works.
