Wakeup on pin change.. how?!
Curt
PostPosted: Thu May 01, 2003 12:36 pm     Reply with quote
I see many references to "when configured" about waking up on a pin change, but cannot find how to configure it.
I see this #define in my 16c505.h "example"-
#define PIN_CHANGE_FROM_SLEEP 0x90
Which seems promising, but is not mentioned anywhere in the documentation.
help?
-Curt
___________________________
Original Post ID: 14121
Curt
Re: Wakeup on pin change.. how?!
PostPosted: Thu May 01, 2003 12:47 pm     Reply with quote
finnaly found the appropriate bit in the status register (/RBWU) and am attemptin to manually set this to '0' but how is it "supposed" to be done with the compiler? Docs are quite sketchy.
-Curt
Original Post ID: 14122
PostPosted: Thu May 01, 2003 1:15 pm     Reply with quote
:=finnaly found the appropriate bit in the status register (/RBWU) and am attemptin to manually set this to '0' but how is it "supposed" to be done with the compiler? Docs are quite sketchy.
The RBWU bit is in the Option register. CCS has a macro
in the EX_MACRO.C file that can be used to write to that
register. EX_MACRO.C is in c:\Program Files\Picc\Examples
Here's the macro:
<PRE>
#define set_options(value) {#ASM \
MOVLW value \
OPTION \
#ENDASM}
</PRE>
Because the Option register is Write-only, you also have
to specify the other bits properly, when you write to it.
ie., RBPU, TOCS, etc. These are discussed in the 16c505
data sheet in section 4.4.
Original Post ID: 14123
Curt
Brute force solution works, but still woudl like to know how
PostPosted: Thu May 01, 2003 1:24 pm     Reply with quote
This code works-
// perform setup of environment
set_tris_b( 0x1A ); // 11010
set_tris_c( 0x0F ); // 1111
// enable wakeup-on-pin-change
#asm
movlw 0x18
option
#endasm
output_low( FET0 );
g_bTriggerState = input( TRIGGER ); // read trigger
if ( !input(L_RESET_SW) ) // its depressed, wait for it to come back up
sleep();
// okay it was released, determine power state
if ( g_onOff && !g_bTriggerState ) // was on, turn off
g_onOff = false;
output_low( LED );
sleep();
else // was off, turn on
g_onOff = true;
output_high( LED );
Original Post ID: 14124
Curt
Thanks Mr. Programmer!
PostPosted: Thu May 01, 2003 1:39 pm     Reply with quote
I guess my solution was the un-macroed version Smile I appreciate your quick feedback.
-Curt
Original Post ID: 14126
