TIMER1 stop working
overmindx
TIMER1 stop working
PostPosted: Tue Oct 05, 2010 2:30 am     Reply with quote
Hi everybody, I have a setup that gets a sensor reading every 15 mins. and stores it in a flash memory. The flash memory communicates via SPI while the sensor uses serial communication. I used an external 32.7658khz oscillator as RTC in TIMER1. With code manipulation, this cause an interrupt every second. It has been working for almost two weeks and suddenly it stopped acquiring data. I noticed that the TIMER1 stopped having interrupts. Its like the TIMER1 stopped working. Can anybody tell me why this happens? I don't have a clue as to why this happens. Please help. Thanks.
Here are snippets of my code.
#include <18F26K20.h>
#device adc=10
#device PASS_STRINGS = IN_RAM
#include <stdlib.h>
#include <string.h>
#FUSES NOWDT, INTRC_IO, NOPROTECT, NOIESO, BROWNOUT, PUT, NOCPD, STVREN, NODEBUG, NOLVP, NOWRT, NOWRTD, NOEBTR, NOCPB, NOEBTRB, NOWRTC, NOWRTB, FCMEN, NOXINST, PBADEN, LPT1OSC, MCLR
#use delay(clock=16000000)
#use rs232(baud=9600, xmit=PIN_B4, rcv=PIN_B3, stream=PC)
#use rs232(baud=4800, xmit=PIN_B2, rcv=PIN_B1, stream=SNSR)
#Byte TMR1H = 0xFCF   // TIMER1 HIGH BYTE
#Byte T1CON = 0xFCD  //TIMER1 CONFIG REGISTER
// i have also enabled these interrupts in main()
 setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1|T1_CLK_OUT);
 enable_interrupts(int_rda);
 enable_interrupts(int_ext);
// this is my code to handle the interrupt in TIMER1
#int_TIMER1
void TIMER1_isr()
   bit_clear(T1CON,7);
   Bit_Set(TMR1H,7);
   Bit_Set(T1CON,7);
   if (++sec>59){
      sec=0;
      testFlag=true;
      if(++min>59){
         min=0;
         HourGprs++;
         HourBool=1;
         if(++hour>23){
            hour=0;
            ++days;
            if ((days == 29 && Month== 2 && !IS_LEAP(Year))
               || (days == 30 && Month==2)
               || (days == 31 && (month==4 || month==6 || month==9 || month==11))
               || (days == 32)
               ){month++;days=0;}
            if(month == 13) {year++; month=0;}
   if ((min==0) || (min == 15) || (min == 30) || (min == 45) )
      if (checkMinute == FALSE)
         checkMinute = TRUE;
         samplingFlag = TRUE;
      checkMinute = FALSE;
PostPosted: Tue Oct 05, 2010 7:44 am     Reply with quote
It is probably not the timer, but something else hanging, and stopping the timer from working.
Obvious question, you have INT_RDA enabled, yet neither of the serial streams you show use the pins for the hardware serial?...
If the hardware UART is available, add 'debug' entries to your code, using this, that send one byte when routines are entered, with a different byte value for each routine. The last byte sent when the hang occurs will help to narrow down what is happening. One 'guess' would be that interrupts are getting disabled somewhere and not re-enabled.
If you are using the hardware UART, make sure you are handling overrun errors, or have 'ERRORS' in the UART definition, otherwise a missed character here, could hang the UART, and then the code. This also may be happening even with 'ERRORS' enabled, unless CCS specifically has handling for the two EUSART erratas on this chip.
