Counter code
delifadzli
Counter code
PostPosted: Sat Sep 25, 2010 1:24 pm     Reply with quote
#include <16F877A.H>
#device ADC=10
#use delay(clock = 20000000)
#include "C:\Users\deli\Desktop\COde\maximum\brum\Flexlcd2.c"
#define      LED1     PIN_D7
#define      LED2     PIN_D6
#define      LED3     PIN_C4
#define      EXIT     PIN_C7
#define      EXIT2    PIN_C6
#define      ZERO     PIN_C5
       int16 temp_adc=0,counter1;
       int inout_counter=0,pir1,pir2,in,out;
       int temp;
        setup_adc(ADC_CLOCK_DIV_8);
        setup_adc_ports(PIN_A1);
        set_adc_channel(1); //read analog input from channel 1
                pir1=0;
                pir2=0;
                in=0;
                out=0;
                temp_adc = read_adc();
               temp=5.00*temp_adc*100.00/1023.00;
               lcd_gotoxy(1,1);
               printf(lcd_putc,"count:%d",inout_counter);
               lcd_gotoxy(1,2);
               printf(lcd_putc,"Temp:%d",temp);
            pir1 = input(PIN_D5);
            pir2 = input(PIN_D4);
            if(pir1==1)
            output_high(EXIT);
            for(counter1=10000;counter1>0;counter1--)
               pir2 = input(PIN_B7);
               delay_ms(1);
               if(pir2==1)
               in=1;
            if(in==1)
            inout_counter++;
          else if(pir2==1)
               output_high(EXIT2);
               pir1 = input(PIN_B6);
               delay_ms(1);
               if(pir1==1)
               out=1;
            if(out==1)
            inout_counter--;
          if(inout_counter==0)
           //output_high(LED1);   //desired output
           //output_low(LED2);
           //output_low(EXIT);
           //output_low(EXIT2);
           output_low(LED2);
           output_low(LED3);
           output_low(LED1);
           output_high(ZERO);
             if((temp<20))
            output_high(LED1);
            output_low(LED2);
            output_low(LED3);
            else if ((temp>= 20) && (temp <30))
            output_high(LED2);
            output_low(LED1);
            output_low(LED3);
            output_high(LED3);
            output_low(LED1);
            output_low(LED2);
Here is the code that I had managed to compile without error.
Here I'm using 2 PIR sensor
The situation that I had achieve regarding counter aspect is
if PIR 1 on , then PIR 2 on the counter will increment.
The situation is , the count only can increase, if the PIR 1 firstly off, before checking the second sensor(PIR2)
Here i want to ask, how to make it more reliable like;
When checking PIR2 condition, it will ignore the condition of PIR1 either on or off....and if PIR2 on-- it will make the count increase,...
The same goes for decrement section.
Or can anyone suggest any suitable counter approach like:
- isn't needed any IC counter?
- new way on counter-- isn't more suitable to use interrupts
*Actually I don't quite familiar with interrupts routine.
sorry for my weakness...
PostPosted: Sun Sep 26, 2010 5:44 pm     Reply with quote
I didn't try to solve your problem, but I noticed the line above is wrong.
That function does not use pin numbers as the parameter.
It works in your program, but it's because you're lucky. The number
represented by PIN_A1 just happens to enable pin A1 as an analog pin.
To find the correct value to use as the parameter, look in this section
of the 16F877a.h file:
// Constants used in SETUP_ADC_PORTS() are:
Wayne_
PostPosted: Mon Sep 27, 2010 1:59 am     Reply with quote
Your problem lies here:-
      if(pir1==1)
            output_high(EXIT);
               delay_ms(1);
               if(pir2==1)
               in=1;
            if(in==1)
            inout_counter++;
          else if(pir2==1)  // <<<<<<<<<<------------------
The else forces it to only check if the previous (pir1==1) condition is false.
Remove the else and the check on pir2 will be independent of pir1.
