Problem with PWM
Abdulla M.A.
View user's profile Send private message Visit poster's website Yahoo Messenger
Problem with PWM
PostPosted: Sun Sep 19, 2010 9:50 am     Reply with quote
Hi guys,
If would like to remove the marks in the signal below, so what I have to
do???
my code:
#include <18f4550.h>
#fuses xt,nowdt,nocpd,nolvp,noprotect
#byte portb=0x06
void send_1();
void send_0();
void send_code();
   set_tris_b(0x00);
         send_code();
void send_1()
   setup_ccp1(CCP_PWM_l_l);
   setup_timer_2(t2_div_by_1,26,1);
   set_pwm1_duty(12);
   delay_ms(1);
   setup_ccp1(ccp_off);
   delay_ms(2);
void send_0()
   setup_ccp1(ccp_pwm_l_l);
   set_pwm1_duty(12);
   delay_ms(1);
   delay_ms(1);
void send_code()
   send_1();
   send_0();
   send_0();
   send_0();
thankx, Abdulla
"A scientist can discover a new star, but he cannot make one. He would have to ask an engineer to do that."
"For an optimist the glass is half full, for a pessimist it's half empty, and for an engineer is twice bigger than necessary."
John P
PostPosted: Sun Sep 19, 2010 11:43 am     Reply with quote
How about instead of the line
you set the duty cycle to 0? That has the effect of making the PWM output always low.
Abdulla M.A.
PostPosted: Mon Sep 20, 2010 4:51 am     Reply with quote
Yes, it became low after I made the duty cycle=0, and remove L_L
from the setup_ccp1(ccp_pwm1_l_l); but it's not pure low, it's about 0.7v. Thank you.
Can you tell me, why setup_pwm1(ccp_off); did not work???
Abdulla
John P
PostPosted: Tue Sep 21, 2010 6:34 am     Reply with quote
My guess is that the setup_pwm1(ccp_off) command just stops the counter at whatever value the output has at that instant, and it might end up high or low. You could check this by looking at the LST file to see what assembly language instructions are used, and then going to the chip manual to see what should be happening--not always totally easy to understand, though! I'd be somewhat disappointed that this instruction leaves a random result, but as you see, there is a workaround.
Abdulla M.A.
PostPosted: Thu Sep 23, 2010 1:28 pm     Reply with quote
Thank you alot John for your help.
Abdulla
