Bart Diricx
#org usage |
Posted: Thu Sep 16, 2010 8:49 am |
I'm making firmware for a PIC16F88 µC which needs to have a I2C bootloader. I want all functions which might get executed prior to finishing the bootloader to be put in address range 0x0E40 - 0x0FFF.
If I do the following:
-> main.h:
void bootloader (void);
void init (void);
-> main.c:
#ORG 0x0E40 0x0FFF // define bootloader segment
init();
bootloader();
#ORG 0x0E40 // located in bootloader segment
void init (void)
I get "Error 166 "main.c" Line 150(1,2): Invalid overload function bootloader
If I don't place the function prototypes in main.h, and declare the functions prior to void main (void) then it builds correctly. Also when I don't put the #org statements, it builds correctly, but isn't placed in the correct memory segments.
Why can't it handle function prototypes when using #org statements? Is there a workaround / solution for this?
I'm using PCWH 4.0.69.
Best regards,
Diricx Bart |
Posted: Thu Sep 16, 2010 2:51 pm |
I was able to make it compile by putting #separate above each prototype.
Quote: |
// main.h
#separate
void bootloader(void);
#separate
void init(void);
Bart Diricx
Posted: Fri Sep 17, 2010 1:03 am |
Thanks, this works indeed ! |
Posted: Sat Sep 18, 2010 8:01 am |
It makes a lot of sense if you think about it.
If you remember that for 'single call' functions, the default is always to put them 'inline', the original prototype for the function, effectively becomes:
#inline
You then when you come to the 'real' definition, tell the compiler to put this function as a distinct entity, somewhere else, which then clashes with the original definition.
By using #separate, you are telling the compiler to treat this as an entity that is _not_ going to be put inline, which then agrees with the latter definition.
Makes total sense, just a pity it is not documented!.
