PIC24FJ128GB106 int16 to int32 error
Piccolo
PostPosted: Thu Sep 09, 2010 1:22 pm     Reply with quote
Using PCWHD IDE 4.112
Part is PIC24FJ128GB106 w/ Date code 10171R6
Here's my test code:
MyInt16 = 32768;
    MyInt32 = (int32)MyInt16;
    Set_LCD_Page(9);
    printf(lcd_putc,"MyInt16  %Lu         ", MyInt16);
    Set_LCD_Page(10);
    printf(lcd_putc,"MyInt32  %Lu         ", MyInt32);
    delay_ms(1500);
the output on the LCD is:
MyInt16 32768
MyInt32 429493452
Any int16 value below 32768 converts to int32 without error.
Any int16 value >= 32768 is wrong.
Any suggestions greatly appreciated.
Here's the ASM listing:
    .................... MyInt16 = 32768;
    03BDC: MOV #8000,W4
    03BDE: MOV W4,830
    .................... MyInt32 = (int32)MyInt16;
    03BE0: PUSH 830
    03BE2: POP 832
    03BE4: CLR W4
    03BE6: BTSC.B 833.7
    03BE8: SETM W4
    03BEA: MOV W4,834
    .................... Set_LCD_Page(9);
PostPosted: Thu Sep 09, 2010 2:41 pm     Reply with quote
This is what you'd expect....
Reason is that by default, the PCD compiler treats integers as signed, so an int16, can't hold values over 32767. Use the unsigned keyword on the int16 declaration.
One of the little 'caveats' on the switch to the later chips.
Piccolo
PostPosted: Thu Sep 09, 2010 3:05 pm     Reply with quote
I changed int16 to unsigned int16 and then it worked just fine.
Thank you for your help.
