principia
Input pin not responding [RESOLVED] |
Posted: Thu Sep 09, 2010 4:41 pm |
I've been struggling with this problem on my own for too long now. It's particularly frustrating because it appears to be so simple! Please help!?
Setup: 18F45J11 running off internal clock at 8MHz. On pin B0, there is a 10k pullup resistor to 3.3V and switch to ground.
A simple program drives a couple of LEDs depending on the input switch position.
Problem: The MCU does not recognise the input level change on B0 - so the LEDs don't toggle. If I reconfigure software and hardware so that B3 is used instead of B0, it all works as expected, and the LEDs toggle. B0 is the only input I've had problems with.
Compiler: 4.112
Problem seen in Run and Debug.
I've run a similar program on a 18F4520 and it all works fine. I suspect I've messed up a fuse setting somewhere, but can I find it?!?!
#include <45j11 input test.h>
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_spi2(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_ccp1(CCP_OFF);
setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
set_tris_b(0x09);
short my_led;
output_high(PIN_B5);
while(true){
my_led=input(PIN_B0);
//my_led=input(PIN_B3);
output_bit(PIN_B1,~my_led);
output_bit(PIN_B2,my_led);
#include <18F45J11.h>
#device ICD=TRUE
#device adc=8
#FUSES INTRC //Internal RC Osc
#FUSES DEBUG //Debug mode for use with ICD
#FUSES NOSTVREN //Stack full/underflow will not cause reset
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOIOL1WAY //Allows multiple reconfigurations of peripheral pins
#FUSES NOWPCFG
#FUSES WPBEG
#FUSES WPDIS
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES T1DIG
#FUSES MSSPMSK7
#FUSES DSWDT2147483648
#FUSES NODSWDT
#FUSES NODSBOR
#FUSES RTCOSC_T1
#FUSES DSWDTOSC_INT
#FUSES WPFP
#use delay(int=8000000)
#use standard_io(B)
Many thanks
Richard
Re: Input pin not responding |
Posted: Thu Sep 09, 2010 7:31 pm |
principia wrote: | Setup: 18F45J11 running off internal clock at 8MHz. |
This doesn't match with:
Code: | #include <18F4520.h> | and
Code: | #use delay(clock=20000000) |
Less important, but
Code: | setup_spi(SPI_SS_DISABLED);
| This is an error in the CCS code wizard. To turn SPI off you have to pass the FALSE parameter. |
principia
Posted: Fri Sep 10, 2010 12:55 am |
Thanks. Of course, I copied/pasted from the wrong header.... I've edited my original post now to show the contents of the correct file.
Also tried the setup_spi change.
But...still the same problem. By the way, I've repeated this on two separate boards, so I don't think there's a build fault on the hardware.
Richard |
principia
Resolved! |
Posted: Fri Sep 10, 2010 6:05 am |
Now resolved after much frustration.
I had a detailed look at the registers associated with PORT B. It looks as if one of them, ANCON1, is not set correctly by the setup_adc_ports() or setup_adc() routines. The compiler was setting this to 0x0F rather than 0x1F. This means that the pin B0/AN12 was being configured as an A/D input and not a DIO.
So I have now forced this manually as follows:
#byte ANCON1 = 0xF49
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_spi2(FALSE);
setup_wdt(WDT_OFF);
setup_timer_0(T0_OFF);
short my_led;
output_b(0);
ANCON1 = 0x1F;
set_tris_b(0x09);
while(true){
Looks like a possible bug in the compiler do you think?
Richard |
