Disable programming of Data EEPROM in IDE
MGP
PostPosted: Sat Aug 28, 2010 9:26 pm     Reply with quote
I'm using PCWH and have found that the IDE writes the chip Data EEPROM every time a new file is loaded to the chip for debugging.
Is there a way to disable this and only write the program memory and fuses? I have some calibration data in EEPROM that I'd like to preserve between program compile and debug sessions.
I've looked through the CCS C and IDE help files and I can't find any setting to change this.
I know it can be done with a configuration setting in CCSLoad but I can't seem to find a similar setting the IDE configuration.
Wayne_
PostPosted: Tue Aug 31, 2010 1:33 am     Reply with quote
Run ccsload separately, not from the menu. You can then change the settings to not program the data memory.
Please note, I have found ccsload too inconsistent with it's settings and find that it can switch the data programming back on at any time. I think this happens if you program from the IDE again.
MGP
PostPosted: Wed Sep 08, 2010 4:39 am     Reply with quote
Thanks Wayne -- I didn't mean that CCSLoad was clearing the EEPROM, I mean the IDE clears it when I recompile code and it loads it into the chip for debugging in the IDE.
As far as I can tell the IDE debugger doesn't use CCSLoad to program the chip, unless it runs it in the background.
I'm thinking there must be a setting in the IDE options to disable EEPROM programming when the chip is programmed for debugging -- I just can't find it!
