norm
				| PWM,CCP5,Timer4,PIC18F45K22 |
				 Posted: Fri Sep 10, 2010 1:07 pm     |
				I can't get a PWM signal to come out of the RE2 pin 27.
Has anyone else been successful implementing this?
Watching in the MPLAB, CCPR5H never gets loaded from the CCPR5L.
#include <18F45K22.H>
#fuses INTRC_IO, NOLVP, NOPROTECT, NOWDT, NOPUT, BROWNOUT, NOPBADEN, CCP2C1
#use delay(clock=16000000)
#byte ADCON1 = 0xFC1
#bit  TRIGSEL = ADCON1.7
#byte CCP5CON = 0xF54
#bit  DC5B1 = CCP5CON.5
#bit  DC5B0 = CCP5CON.4
#byte CCPTMRS1 = 0xF48
#bit  C5TSEL1 = CCPTMRS1.3
#bit  C5TSEL0 = CCPTMRS1.2
#byte PR4 = 0xF52
#byte TMR4 = 0xF53
#byte CCPR5L = 0xF55
#byte CCPR5H = 0xF56
#byte T4CON = 0xF51
#bit  TMR4ON = T4CON.2
#byte PIR5 = 0xF7E
#bit  TMR4IF = PIR5.0
char dummy=0;
  setup_oscillator(OSC_16MHZ,0);
  disable_interrupts(GLOBAL);
  C5TSEL1 = 0;  // Select Timer 4
  C5TSEL0 = 1;  // Select Timer 4
  setup_timer_4(T4_DIV_BY_1,160,1);
  setup_ccp5(CCP_PWM);
  set_pwm5_duty(100L);
  while (1)
  dummy++;
} /*********************** end of main *************/
Section of List file
....................   C5TSEL1 = 0;
003E:  MOVLB  F
0040:  BCF    x48.3
....................   C5TSEL0 = 1;
0042:  BSF    x48.2
....................   setup_timer_4(T4_DIV_BY_1,160,1);
0044:  MOVLW  00
0046:  IORLW  04
0048:  MOVWF  x51
004A:  MOVLW  A0
004C:  MOVWF  x52
....................   setup_ccp5(CCP_PWM);
004E:  BCF    F96.2
0050:  BCF    F8D.2
0052:  MOVLW  0C
0054:  MOVWF  x54
....................   set_pwm5_duty(100L);
0056:  MOVLW  19
0058:  MOVWF  x55
005A:  MOVF   x54,W
005C:  ANDLW  CF
005E:  MOVWF  x54
I'm surprised to see this in the list, some statements make use of it, and others don't.
003E:  MOVLB  F
Thanks  Norm |
