how to use timer0
hemnath
how to use timer0
PostPosted: Thu Oct 18, 2012 7:29 am     Reply with quote
i did programming using delays. looking forward to do with timer0.
compiler - CCS c compiler
pic - 18F2520.
internal oscillator - 4MHz
Please help how to start with? how to calculate time?
thanks in advance Smile
Mike Walne
PostPosted: Thu Oct 18, 2012 9:27 am     Reply with quote
It's all in the data sheet.
Timer0 advances on each instruction cycle that's 4 oscillator cycles or 1us, with your 4MHz clock.
Timer0 can be either an 8 or 16 bit counter timer.
You use Timer0 overflow to trigger an interrupt.
So in 8 bit mode it will trigger every 256us with no prescaler.
In 8 bit mode and 1:2 prescaler interrupts at 512us etc.
Mike
hemnath
PostPosted: Thu Oct 18, 2012 9:33 am     Reply with quote
Thanks for the information.
I'm blinking the led with 5 sec delay. please tell that I'm doing it right?
#include "18F2520.h"
#fuses HS, NOPROTECT, INTRC_IO
#use delay(clock=4000000)   // 4MHZ internal clock
//   fout = fclk/(4*prescaler* (256-TMR0)*count)
//    for prescaler = 1 : 256 and TMR0 = 0
//   if need 5sec delay
//   Tout = 1/fout = 1/0.2Hz = 5sec
//   count = 4Mhz/(4*256*(256-0)*0.2Hz) = 76.29 = 76 counts(approxi)
unsigned int count;
#int_RTCC
void clock_isr()
set_timer0(0);
count++;
if(count==76)    // 76 for 5sec  delay // 15 for 1 sec delay
   output_high(PIN_B7);
   count=0;
set_tris_b(0x00);
setup_oscillator(OSC_4MHZ);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256|RTCC_8_BIT);
   output_high(PIN_B6);
Mike Walne
PostPosted: Thu Oct 18, 2012 11:09 am     Reply with quote
I'm assuming you've got an LED connected to pin B7.
As it stands you're turning the LED on after 5s then no more changes.
If you want it to flash you can use the toggle function.
If you have a real board in front of you, it should be obvious by now.
You don't need the set_timer(0) line. When timer0 overflows its value will be zero. By the time you get into the interrupt routine timer0 will have advanced, so resetting it to zero again screws up your timings.
Mike
juan
View user's profile Send private message AIM Address ICQ Number
PostPosted: Tue Apr 21, 2015 3:08 pm     Reply with quote
Mike
me sirvio el ejemplo, gracias
juan
Re: how to use timer0
PostPosted: Tue Apr 21, 2015 3:11 pm     Reply with quote
pic - 18F2520.
Can you give me an example ? Thanks.
asmboy
PostPosted: Sat Apr 25, 2015 12:33 pm     Reply with quote
maybe this will point you in a helpful direction,
http://www.ccsinfo.com/forum/viewtopic.php?t=53857
PostPosted: Sun Apr 26, 2015 2:28 am     Reply with quote
Let me add a couple of comments.
In the code library, there is a routine 'Timer based Real Time Clock (RTC)', which shows a way to generate long term accurate times by actually effectively counting clock cycles between the interrupts. This approach can be used without the complexity of actually updating a set of clock variables, to give nice accurate times from any timer. Worth studying.
The start of this post also mentions the other approach. Basically if you have a timer like timer2, which can be programmed for a particular count, then you can generate an interrupt that occurs at a much nicer interval. So (for instance), if you set timer2 to use 249 (so counts 0 to 249), (Fosc/4)/4, and interrupt every ten cycles, then this interrupt will give:
4000000/(4*4*250*10) = 100Hz.
Advantage is it makes counts really easy to work out!. Also generally it is useful to have a system 'tick' at a nice regular interval like this. Downside is the limited number of timers supporting this, hence the other approach if needed.
Generally it'd be much easier to see what was going on, if the interrupt did something like toggling the LED....
