return to start of main() from ISR
eng.alamin
PostPosted: Mon Aug 30, 2010 5:01 pm     Reply with quote
Hello Guys
I would like to know is it possible to return from interrupt routine directly to the head of the main() function (not to the place where the interrupt occurred).
For example I wrote a program to read from three different sensors:
#INT_TIMER0
 void  TIMER0_isr(void)  // interrupt every 1 second
 if(flow >=2)
           flow = 0 ;
          s1=0;
          s2=0;
          s3=0
        else flow ++;
void sensor1();
void sensor2();
void sensor3();
main()
 if(flow == 0 && R==0)
   R =1 ;
sensor1();  // .5 second required for the reading
if(flow == 1 && C==0)
   C =1 ;
sensor2();// .5 second required for the reading
if(flow == 2 && A==0)
   A =1 ;
sensor3();// .5 second required for the reading
Well this is not multi-tasking nor threading or what so ever.
I just want to make sure if any one of my sensors is tripping the rest will continue working.
PostPosted: Mon Aug 30, 2010 7:19 pm     Reply with quote
To narrowly answer your question, without looking at program design
issues, see this thread on the reset_cpu() function.
http://www.ccsinfo.com/forum/viewtopic.php?t=18165
jventerprises
jump to main
PostPosted: Tue Aug 31, 2010 9:09 am     Reply with quote
well, i'm not sure this is a supported function, and the manual clearly says pointers to functions are not allowed...... but.....
i have done this in the past on 18F series parts and it works.
int32 *main_ptr;
main_ptr = &main;
goto_address(main_ptr);
this jumps to main.
a cleaner way is to just reset the cpu with a reset_cpu();
Jon
