hisham.i
PWM problem |
Posted: Sat Aug 28, 2010 2:46 am |
Am using pic18f2331 to generate multiple pwm outputs. I wrote a test code to see the pwm output, and this is my code:
#include<18F2331.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOBROWNOUT, PUT
#use delay(clock=8000000)
#define POWER_PWM_PERIOD 255 // 1 KHz pwm freq with 8 MHz osc.
setup_power_pwm_pins(PWM_COMPLEMENTARY, PWM_COMPLEMENTARY, PWM_OFF, PWM_OFF);
setup_power_pwm(PWM_FREE_RUN, 1, 0, POWER_PWM_PERIOD, 0, 1,0);
set_power_pwm0_duty(128); //Duty 0
set_power_pwm2_duty(50); // Duty 1
When I put pwm period to 255 and pwm0 duty cycle to 128, I predict that I should get 50% duty cycle, but testing this program in Proteus doesn't give so.
How to calculate the value in the duty cycle according to the value in the period?
What is the my problem?
Thanks |
hisham.i
Posted: Sun Aug 29, 2010 7:09 am |
Thank you PCM programmer,
I have one more question...
If i put the time base value=0, and the period=3124, with the postscalar =1, does it mean that every time the time base is equal to 3124 an interrupt occur? |
Posted: Sun Aug 29, 2010 6:25 pm |
You can find the answer by yourself, by making a test program.
For example, the program shown below will output a 50% duty cycle
pwm pulse on pin B3. The interrupt routine will put out a short pulse
on Pin E0 when a PWM Timebase interrupt occurs. What is the frequency
of the signals on pins B3 and E0 ? On my oscillosope they are both about
633 Hz. So, that means the PWM interrupt is occuring at the same rate
as the PWM signal.
Now do the math. Look in the Power PWM section of the 18F4431 data
sheet. Look at the equation below, from the data sheet. It shows that
the PWM period counter runs from the instruction clock (Fosc /4).
EQUATION 17-1: PWM PERIOD FOR
FREE-RUNNING MODE
(PTPER + 1) x PTMRPS
TPWM = ---------------------
FOSC/4
So with a 8 MHz oscillator, the instruction clock is 2 MHz.
Now do this equation: 2 MHz / (3124 +1) = 640 Hz
I am not sure why there is a difference between the calculated frequency
of 640 Hz and the measured value of 633 Hz. It can't be caused by
interrupt latency because we are not resetting any PWM counters inside
the interrupt routine. The descrepancy amounts to about 35 instruction
cycles. The measured interrupt rate is slower than it should be by that
amount. I'm sure there is a reason, I just don't have time to find out
what it is right now.
But anyway, the answer to your question is yes. You'll get an interrupt
once per PWM period.
#include<18F4431.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, NOBROWNOUT, PUT, NOLVP
#define POWER_PWM_PERIOD 3124 // For testing
#int_pwmtb
void pwm_isr(void)
// Make a pulse on Pin E0 for the frequency counter.
output_high(PIN_E0);
delay_us(100);
output_low(PIN_E0);
// Setup the 4 Power PWM channels as ordinary pwm channels.
setup_power_pwm_pins(PWM_ODD_ON, PWM_ODD_ON, PWM_ODD_ON, PWM_ODD_ON);
// Mode = Free Run
// Postscale = 1 (1-16) Timebase output postscaler
// TimeBase = 0 (0-65355) Initial value of PWM Timebase
// Period = 2000 (0-4095) Max value of PWM TimeBase
// Compare = 0 (Timebase value for special event trigger)
// Compare Postscale = 1 (Postscaler for Compare value)
// Dead Time
set_power_pwm0_duty((int16)((POWER_PWM_PERIOD *4) * .5)); // 50% duty cycle
clear_interrupt(INT_PWMTB);
enable_interrupts(INT_PWMTB);
