collink
XINST support |
Posted: Sat Aug 28, 2010 4:28 pm |
So, I have repeatedly read that XINST is the kiss of death for the CCS compiler. And, I also see the same thing in regards to the SDCC compiler. (Or, at least it does not support it.) I don't know about the other PIC compilers. So, does anyone know why multiple PIC compilers don't bother to support an extended instruction set which was designed specifically FOR compilers?!?! Why in the world would XINST support not be something that they'd do everything to support? Am I missing something? |
collink
Posted: Sat Aug 28, 2010 4:49 pm |
Replying to myself... I guess the PIC18 manual at 25.2.3 explains why they don't support it... Well, it would still be nice if they would.
For anyone interested, the reason XINST blows up most programs is that it changes the way that almost half of the PIC instructions are interpreted even if you never use the extended instructions. Basically a bunch of instructions start to support and use indexed addressing with literal offsets. This is as opposed to how the instructions previously used only literal values. The change causes a bunch of code to not work the same. This can be corrected if the compiler expects that behavior but it's apparent that CCS does not do that.
For what it's worth, I think that a lot of people would have liked to know WHY you can't enable XINST and until now that reason seems to never have been posted to this forum. That's a shame. But, now you know. ;) |
bkamen
Posted: Sat Aug 28, 2010 5:05 pm |
I asked CCS Support in a thread covering something else once and got the answer you posted and then looked it up..
So my question was answered, but you are right -- it'd probably be a nice Sticky Post at the top of the list for this section so people can read up on it.
