jumpus
Constant interrupt 16F690 |
Posted: Sun Aug 29, 2010 10:21 pm |
I'm having an annoying problem with my PICkit2 starter kit (low pin count demo board). I'm trying to get some useful function out of the port B interrupts, but it constantly fires. I've tried all kinds of things: nothing connected to ANY port B pins, pullups enabled..interrupt constantly fires. Clear RABIF (using "clear_interrupt(INT_RB)" and even manually) even though i shouldn't have to....interrupt constantly fires.
I even saw another thread that suggested to enable port A interrupts (although not assign an isr) so I tried that and same thing....interrupt fires continually.
I'm beginning to suspect a hardware problem, although I have checked with my volt meter and B4-7 seem to remain at constant voltage even while the interrupt fires. I wish I had an oscilloscope to take a closer look at the voltages on those pins, but alas I do not. I've posted my code below, although it's about as basic as possible.
#include <16F690.h>
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT
int toggle=0;
#int_RB
void chA_isr(){
if(toggle==0){
toggle = 1;
output_high(PIN_C1);
}else if(toggle==1){
toggle = 0;
output_low(PIN_C1);
port_b_pullups(0xF0);
delay_us(10); //wait for pullups to pull up
//These lines to enable interrupts:
clear_interrupt(INT_RB);
enable_interrupts(INT_RB); //enables interrupt on port B
enable_interrupts(global); //enables interrupts globally
while (TRUE) {
output_high(PIN_C0);
output_low(PIN_C0);
It's all part of a bigger picture but the code, as posted above, elicits the problem behavior. Even with NOTHING attached (ok, so i soldered some leads to B4-6, but they're not connected to anything) the interrupt fires constantly (led for C1 blinks) and never allows the main program to execute (led for C0 never so much as flickers). As I write this, the code above is running, its mocking blink edging me ever closer towards insanity. To be sure, I just poked pins B4-7 with the volt meter and all read a constant 5V (ok, 4.91, but I feel like that should be close enough).
Oh, and from ".lst": Code: | CCS PCM C Compiler, Version 4.093, 5967 29-Aug-10 22:02 |
Any ideas?
Thanks in advance!
-K |
Posted: Mon Aug 30, 2010 12:56 am |
If you searched the internet or this forum you would have found that many people have problems with the PortB interrupts. These interrupts are a bit different in that two actions are required to clear the interrupt: data sheet chapter 4.4.2 wrote: | The user, in the Interrupt Service Routine, clears the interrupt by:
a)Any read or write of PORTB. This will end the
mismatch condition.
b)Clear the flag bit RABIF | Clearing the RABIF is something the CCS compiler does for you, but it is up to you to read the I/O port (and determine the pin that changed, causing the interrupt). |
andrewg
Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Posted: Mon Aug 30, 2010 12:58 am |
You need to read port B to clear the interrupt. eg "input_b" or "input(PIN_Bx)". _________________ Andrew |
jumpus
Posted: Mon Aug 30, 2010 9:30 am |
Well... I feel like an idiot now. That's ok, though. It works!
In my defense, I actually saw that I should be reading that port (in the data sheet and on this forum) but I interpreted it as either read the port or clear RABIF. Live and learn...
Thanks guys!
-K |
Douglas Kennedy
Posted: Mon Aug 30, 2010 12:51 pm |
As an aside it is almost never a good idea to put a delay_ms in an isr. If you have a mechanical device aka switch remember it will need debouncing since each bounce may trigger a new interrupt. |
