PWM 16f877a
farouk_baya
PWM 16f877a
PostPosted: Wed Aug 25, 2010 3:55 pm     Reply with quote
I use L298 + 16f877a.
When I tested the L298 it works fine. I put 5v to input Enables to test it.
#include "16F877.h"
#fuses XT,PUT, NOWDT, NOPROTECT, BROWNOUT,  NOLVP
#use delay(clock = 4M)
main()
int8 x=0;
output_low(PIN_C2);
setup_ccp1(CCP_PWM);
setup_timer_2(T2_DIV_BY_4,249, 1);  // 1000 Hz
set_pwm1_duty(62);
   if (x==249)
      x=0;
     x=x+10;
  set_pwm1_duty(x);
  delay_ms(2000);
The problem that I hear a sound from the motors but nothing is happening.
thanks for help.
nilsener
PostPosted: Fri Aug 27, 2010 1:59 am     Reply with quote
as you increment x by 10 (x=x+10;), x will never be 249 and your
if (x==249)
   x=0;
will never be entered. Try
if (x > 249)
   x=0;
or something similar.
I think this is not the reason why your motor is not running, but worth to check.
