2 interrupts problem
neverlog
PostPosted: Wed Aug 25, 2010 3:01 am     Reply with quote
Dear All,
I really wish you can help me for the below:
I am doing a RFID controller, I have 8 unit RFID controller(Slave) which linked with each other via BUS(I use ex_PBUSM.c for the communication)
My problem is my RFID controller is always communicate with RFID reader to retrieve and send command/data. I use interrupt for the data receiving thru UART.
My master controller will be communicating with the RFID controller via ex_PBUSM.c method which is also using interrupts.
In the RFID controller, can I use 2 interrupts for RFID reader part and Communication with Master? My highest priority will be on RFID reader part.
Please help. 1000 thanks!
neverlog
PostPosted: Wed Aug 25, 2010 7:48 pm     Reply with quote
I have found a method call RTOS.
Is RTOS suitable to run 2 critical task which required more than 2 interrupts as both high priority.
Or PIC itself is not meant for RTOS? Any advice will be appreciated.
