#int_rb and One button for different functions
kmp84
PostPosted: Thu Aug 12, 2010 9:17 am     Reply with quote
Hi Friends!! Can anybody help me with example for #int_rb and #int_timer1 interrupts for making one button with different function? (push without holding ->increment var.count, push with holding 1-2second ->clear var. count)
Thanks before Smile
trirath
PostPosted: Wed Aug 25, 2010 3:44 am     Reply with quote
Let see example and you can modify. It work fine but may not be expert code.
#int_RB
void menu_isr() {
if(!input(PIN_B4)) RB_ready=1;
void main(void){
while(true){
 if(RB_ready){
     while(!input(PIN_B4) && (++timeout<350000)); //PRESS LONG APP 3 SECOND
     beep(); //call Beep routine
                                if(input(PIN_B4))
                                          MENU=!MENU; // Menu is int1
                                          // Loop Menu if press not longer than 3 second
                            if(MENU==0){ //do something// }
                            if(MENU==1){ //do something//}
                           else {  //Press more then 3 second do this
                                   delay_ms(200);
                                         //do something//
                                       timeout=0;
               } //end else
                                      RB_ready=0;
           }//end rB ready
}//end while
}//end main
