generate door bell sound from a pic?
piire
PostPosted: Tue Aug 24, 2010 10:44 am     Reply with quote
Hi there, is it possible to generate a door bell sound such as a ding dong from a pic microcontroller.
If so, can some guide me on how to go about doing this?
I know you can get separate ic which do this for you but I would like to use the pic to reduce the amount of components.
piire.
MikeW
PostPosted: Tue Aug 24, 2010 11:22 am     Reply with quote
Search this forum, also do a google on
"Roman Black BTc"
I haven't used it, but I believe it takes a wav sound file, and outputs on a single PIC pin to produce the sound.
here's roman's web site
http://www.romanblack.com/BTc_alg.htm
Mike
PostPosted: Tue Aug 24, 2010 11:28 am     Reply with quote
Also look at these CCS example and driver files:
c:\program files\picc\examples\ex_tones.c
c:\program files\picc\drivers\tones.c
Also use the forum's search page to search the Code Library forum for:
tone*
