Error 166 Invalid overload function
hebebruecken
PostPosted: Wed Aug 25, 2010 1:06 am     Reply with quote
Hi
What's the reason for this error message?
Thanks for any help.
#define TASTEN 0x30
#define TASTE_YES 0x10
#define TASTE_NO 0x20
#define YES     'Y'
#define NO      'N'
#define BOTH     'B'
#define CALIB   'B'
#define SETUP 'B'
#define TOUT '@'
#SEPARATE
CHAR readKey(SHORT pwrOff)
  if (PORT_B & TASTEN)
   do
     key = PORT_B & TASTEN;
     delayMS(50);
   while (key != PORT_B & TASTEN);
   if (key  ==  TASTE_YES) {  key = YES;  }
      if (key ==  TASTE_NO)  { key = NO;   }
        if (key ==  TASTEN)   { key = CALIB;  }
   if (pwrOff == FALSE)     {   powerOff = DLY_POWER;   }
     key = 0;
  RESTART_WDT( );
  return (key);
PostPosted: Wed Aug 25, 2010 11:42 am     Reply with quote
Your code doesn't compile. It's missing several variable declarations.
This is not a CCS function:
delayMS(50);
It doesn't compile.
Post a test program that has all variable declarations, and an #include
statement for the PIC, #fuses, #use delay(), main(), and the program
must call the readKey() function.
Also post your compiler version.
