My question relates to the Alternate Vector Table on the dsPIC.
Does anybody know if CCS supports automatic code generation for the AVT or do I have to manually populate the table and make sure the interrupt code is appropriately placed in user code space?
thanks _________________ Jon
jventerprises
Clarification
Posted: Thu Aug 19, 2010 9:40 pm
I should be a little clearer....
I want to populate both the normal and alternate vector tables via one project.
#build(ALT_INTERRUPT) populate the AVT, and leaving it out populates the IVT, but I would like to populate both tables and switch between them using
#BUILD(ALT_INTERRUPT) and #BUILD(INTR_NORMAL)
I have not found a way to do this other than to build two projects and load them one on top of the other. _________________ Jon
