eabir
PIC10f220 adc not working |
Posted: Mon Aug 16, 2010 7:47 am |
This code is working great on the PIC16F506-ICD on the debug mode.
But when it programmed and running from the PIC10F220, it seems the ADC isn't working.
I tried any value from 0 to 255, with voltage between VCC to GND.
Attached the compliation and code, is there something bad in the ADC set up ?
#include <10F220.h>
#FUSES NOMCLR //Master Clear pin: disable
#FUSES NOPROTECT //Code protected from reads
//#FUSES IOSC4
//#use delay(Clock=4MHZ,OSC)
#use delay(clock=4000000) // Only for Debug Mode
// #bit OSCCAL_0 = 0x05.0 // Disable OSC on GP2, Enable as I/O
// Voltage Table:
// 0.9v=48 ; 0.8v=45 ; 0.7v=38
// 1v=54 ; 1.1v=59 ; 1.2v=66 ; 1.3v=69/70 ; 1.4v=76 ; 1.5v=81 ; 1.6v=85
// 1.7v=90 ; 1.8v=95 ; 1.9v=101 ;
#define DELAY 1
int flag = 0;
long value = 0;
int step;
unsigned char cnt0 = 0; // counter
unsigned char cnt1 = 0; // counter
unsigned char cnt2 = 0; // counter
unsigned char sGPIO = 0;
setup_adc_ports(sAN1);
setup_adc(ADC_CLOCK_DIV_4);
setup_counters(RTCC_INTERNAL,RTCC_DIV_1|DISABLE_PULLUPS); //|DISABLE_PULLUPS
setup_wdt(WDT_2304MS);
// setup_adc( ALL_ANALOG );
// setup_adc_ports( ALL_ANALOG );
// setup_adc( ADC_OFF );
set_adc_channel(1); //PIN4
// set_adc_channel(0);
SET_TRIS_B(0b11111010); //GP0,1,2 as Output; GP3 as Input(default)
// OSCCAL_0 = 0;
// output_b(0);
// sGPIO = 0;
// Start ADC
while (1) { // ADC Port
read_adc(ADC_START_ONLY);
value = read_adc();
delay_us( 10 );
value=read_adc(ADC_READ_ONLY);
if (value > 10 ){ //&& cnt0 >= 4){
cnt0 = 0;
// beeper_on ();
for(step = 0;step < 5000 ;step++ ){ // Loop control
//cnt0 = 0;
output_low(PIN_B0); // Sound sequence
restart_wdt();
delay_us(168); // 168 = 5khz for DSP
output_high(PIN_B0);
restart_wdt();
delay_us(168);
// beeper_off ();
restart_wdt();
delay_us(168); // 0 = 0khz for DSP
output_low(PIN_B0);
restart_wdt();
delay_us(168);
This is the compliation capture:
Code: | Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\PIC\ADC.ESYM".
Clean Warning: File "C:\PIC\ADC.o" doesn't exist.
Clean: Deleted file "C:\PIC\ADC.HEX".
Clean: Deleted file "C:\PIC\ADC.LST".
Clean: Deleted file "C:\PIC\ADC.PJT".
Clean: Deleted file "C:\PIC\ADC.ERR".
Clean: Deleted file "C:\PIC\ADC.COF".
Clean: Done.
Executing: "C:\Program files\Picc\CCSC.exe" +FB "ADC.c" +DF +LN +T +A +M -Z +Y=9 +EA #__10F220=TRUE
>>> Warning 203 "ADC.c" Line 52(1,1): Condition always TRUE
>>> Warning 203 "ADC.c" Line 66(1,1): Condition always TRUE
>>> Warning 203 "ADC.c" Line 84(1,1): Condition always TRUE
>>> Warning 202 "ADC.c" Line 23(10,14): Variable never used: flag
>>> Warning 202 "ADC.c" Line 27(24,28): Variable never used: cnt1
>>> Warning 202 "ADC.c" Line 28(20,24): Variable never used: cnt2
>>> Warning 202 "ADC.c" Line 29(21,26): Variable never used: sGPIO
Memory usage: ROM=45% RAM=81% - 81%
0 Errors, 7 Warnings.
Loaded C:\PIC\ADC.cof.
BUILD SUCCEEDED: Mon Aug 16 16:30:42 2010 |
Wayne_
Posted: Mon Aug 16, 2010 8:26 am |
int step
you define step as an 8 bit int but expect it to reach 5000. This will never happen.
Once in the loop it will never leave.
Change to
int16 step
*edit*
value = read_adc();
delay_us( 10 );
You set adc to start only but imediately do a read_adc which will override your start. You wait 10 us and then try to read the ADC BUT your previous read will have killed the START_ONLY.
Just use value = read_adc and remove the other stuff.
*edit again*
This is redundant as you are not using fast_io, you can remove it. |
eabir
Well now it works |
Posted: Mon Aug 16, 2010 9:47 am |
Thanks! |
