AD7746 I2C
Jim Lai
AD7746 I2C
PostPosted: Tue Jul 20, 2010 10:09 am     Reply with quote
Hallo: I am new here, just wrote code for AD7746. By CCS compiling it shows NO ERROR, also program can run, but I found it run never down since it halted in the line:
#use i2c(master, sda=Device_SDA, scl=Device_SLC)
Can somebody help me to find errors? Thanks
#include <18f8722.h>
#device ICD=TRUE
//#use delay(internal=1Mhz)
#fuses HS, NOLVP, NOWDT
#define Device_SDA PIN_B1
#define Device_SLC PIN_B0
#define I2C_ADDR_W   0x90
#define I2C_ADDR_R   0x91
#define REG_STATUS      0x00
#define REG_CAP_DATA   0x01
#define REG_VT_DATA      0x04
#define REG_CAP_SETUP   0x07
#define REG_VT_SETUP   0x08
#define REG_EXC_SETUP   0x09
#define REG_CONFIG      0x0A
#define REG_CAP_DAC_A   0x0B
#define REG_CAP_OFFSET   0x0D
#define REG_CAP_GAIN   0x0F
#define REG_CAP_V_GAIN   0x11
#define RESET_ADDR      0xBF
#define CAP_ZERO      0x800000L
void setup()
   //RESET
   i2c_start();
   i2c_write(I2C_ADDR_W);
   i2c_write(RESET_ADDR);
   i2c_stop();
   //wait for a boot
   //Set up and configuration
   i2c_start();
   i2c_write(REG_CAP_SETUP);
   i2c_write(0x80);         //CAP setup, CAPEN single, continue or calib
   i2c_write(0x81);         //VT setup, VTEN, single conversion, continue, calib
   i2c_write(0x0B);         //Exe setup,EXON only on cap, EXCA, EXC Low=0, High=VDD
   i2c_write(0x21);         //Configuration continue conversion
   i2c_write(0x00);         //CAP DAC A setup, disable
   i2c_write(0x00);         //CAP DAC B setup, disable
   i2c_stop();
byte checkStatus()
   BYTE status;
   i2c_start();
   i2c_write(I2C_ADDR_R);
   i2c_write(REG_STATUS);
   i2c_start();
   delay_us(10);
   status = i2c_read(1);
   i2c_stop();
   return(status);
byte *read3Byte(byte REG_ADDR3)
   byte *Array, readyStatus;
   while (readyStatus && 0x5) readyStatus = checkStatus();
   i2c_start();
   i2c_write(REG_ADDR3);
   i2c_start();
   delay_us(10);
   *Array = i2c_read(1);
   *(Array+1) = i2c_read(1);
   *(Array+2) = i2c_read(0);
   i2c_stop();
   return(Array);
byte *read2Byte(byte REG_ADDR2)
   i2c_start();
   i2c_write(REG_ADDR2);
   i2c_start();
   delay_us(10);
   *(Array+1) = i2c_read(0);
   i2c_stop();
   return(Array);
byte *read6Byte()
   i2c_start();
   i2c_write(REG_CAP_DATA);
   i2c_start();
   delay_us(10);
   *(Array+2) = i2c_read(1);
   *(Array+3) = i2c_read(1);
   *(Array+4) = i2c_read(1);
   *(Array+5) = i2c_read(0);
   i2c_stop();
   return(Array);
byte *readREG()
   i2c_start();
   i2c_start();
   delay_us(10);
   *(Array+3) = i2c_read(0);
   i2c_stop();
   return(Array);
void offsetCalib()
   //Set up for offset calib
   i2c_start();
   i2c_write(REG_CONFIG);
   i2c_write(0xFD);         //Configuration offset calib
   i2c_stop();
   delay_ms(5000);
void gainCalib()
   i2c_start();
   i2c_write(0xFE);         //Configuration gain calib
   i2c_stop();
   delay_ms(5000);
#int_rda
void serial_interrupt()
   char c;
   c = getc();
   switch(c) {
      case 'o':
         printf("Please waiting for Offset Calibration");
         offsetCalib();
      case 'g':
         gainCalib();
   byte dataArray[6], REGarray[4];
   enable_interrupts(int_rda);
   enable_interrupts(global);
   setup();
   REGarray = readREG();
   dataArray = read6Byte();
PostPosted: Tue Jul 20, 2010 11:25 am     Reply with quote
byte checkStatus()
BYTE status;
i2c_start();
i2c_start();
delay_us(10);
i2c_stop();
return(status);
You need to do a NACK (parameter 0) on the last i2c_read() in any
transaction.
Also, make sure you have 4.7K pull-up resistors on SDA and SCL.
