smoglu
possibly a bug [RESOLVED] |
Posted: Tue Jul 20, 2010 4:37 am |
Hi. The following little code does not work. 2 LEDs are connected to pin A4 and A5, and pin A4 does not light up the LED but pin A5 does. There is a problem with pin A4.
Compiler Version: 4.068
#include <16F876A.h>
#FUSES HS //High speed Osc (> 4mhz)
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
output_high(PIN_A4);
output_high(PIN_A5);
SherpaDoug
Posted: Tue Jul 20, 2010 5:37 am |
On some PICs pin A4 is Open Collector, ie. it will not pull high, it only pulls low. Check the datasheet for your PIC as I am not familiar with the 16F876A. _________________ The search for better is endless. Instead simply find very good and get the job done. |
smoglu
Posted: Tue Jul 20, 2010 5:53 am |
Yes, you are right. PIC datasheet says A4 is open-drain type.
Thanks. |
