2 pic 1 quartz
denis_11
2 pic 1 quartz
PostPosted: Sun Jul 18, 2010 12:22 pm     Reply with quote
Hello I connect two 12f683 to a single crystal... I have to generate two different pw... say that it works?
Franck26
PostPosted: Sun Jul 18, 2010 12:49 pm     Reply with quote
I don't understand what you are trying to do, but it sound crazy!!!
You cannot connect your quartz to 2 micro as it's done on your schematic.
Good luck
Franck.
PostPosted: Sun Jul 18, 2010 1:29 pm     Reply with quote
Actually there are many threads on this in the Microchip forum:
http://www.microchip.com/forums/m373427.aspx
http://www.microchip.com/forums/m482855.aspx
Humberto
PostPosted: Sun Jul 18, 2010 1:38 pm     Reply with quote
Yes you can. Connecting OSC2 from the U1 to OSC1 of U2 as shown the schematic it is perfectly legal.
Be aware that if you are driving more than -let says- 2 or 3 PICs, you will need a CMOS or TTL driver/buffer
with a bigger fan out than OSC2.
You have to set Oscillator setup (#FUSES) accordingly in each PIC.
For U1
#FUSES XT, .........
For U2
#FUSES EC_IO, .......
#use delay(clock=8000000)
Humberto
denis_11
Franck26 wrote:
Good luck
Franck.
But it's you who make me laugh... you can not answer on a forum if you are not sure of what you are writing....thanks PCM programmer and Humberto:)
Franck26
PostPosted: Sun Jul 18, 2010 3:58 pm     Reply with quote
If I answer only when I'm 100% sure, I would never answer.
At least I made you laugh!!!
You can have a look at the post #12 of this link:
I would add that the clock input pin of the second micro is going to add some capacitance to 1 side of the quartz, which can prevent the oscillation from starting.
This is not something that I would use for a professional circuit, except of course if there is a microchip AN on this topic (and maybe there is).
Franck.
