PIC18F24j50 -> USB dont work !!
slaxtrack
PostPosted: Tue Jul 13, 2010 11:21 pm     Reply with quote
compiler -> 4.104 CCS
Xtal --> 20 Mhz (resonator)
My program:
#include <18F24J50.h>
#device adc=8
#FUSES HSPLL                    //High Speed Crystal/Resonator with PLL enabled
#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES PRIMARY                  //Primary clock is system clock when scs=00
#FUSES NOWPCFG
#FUSES WPEND
#FUSES WPDIS
#FUSES NOCPUDIV
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES T1DIG
#FUSES MSSPMSK7
#FUSES PLLDIV5
#FUSES DSWDT2147483648
#FUSES DSWDT
#FUSES DSBOR
#FUSES RTCOSC_T1
#FUSES DSWDTOSC_INT
#FUSES WPFP0
#FUSES WPFP1
#FUSES WPFP2
#FUSES WPFP3
#FUSES WPFP4
#FUSES WPFP5
#use delay(clock=48000000)
#include <usb_cdc.h>
   char c;
   usb_init_cs();
   while (TRUE)
      usb_task();
      if (usb_cdc_kbhit())
      c=usb_cdc_getc();
      usb_cdc_putc(c+1);
ERROR ---> Unknown device on my PC Sad help me guys please !
rwskinner
PostPosted: Sun Jul 18, 2010 8:11 am     Reply with quote
Did you get it going?
Here is some of my stuff....
#FUSES HSPLL
#FUSES PLLDIV5
#FUSES NOCPUDIV
#FUSES NOXINST
#FUSES NOPROTECT
#FUSES NOLPT1OSC
#FUSES PRIMARY
#USE delay(clock=48000000)
Also, you have to set the PLL up manually in the beginning of your Main....
setup_oscillator(OSC_PLL_ON);
