I am doing LED running display with 20 5X7 LED arrays. I have used that max6953 driver code. There we can have the device address change for max6953. In the hardware also we have AD0 and AD1 for changing the address.
I have done with 4 5X7 LED matrix arrays. It is working fine.
My doubt is how to give the message for all the max6953 at a time?
And how to scroll the image?
Thanks in advance.
Regards,
Varadharaj E _________________ embedding innovation in engineers
evaradharaj
Re:reply
Posted: Fri Jul 16, 2010 1:15 am
Hi all
Please try for answer this .. I am in urgent need. _________________ embedding innovation in engineers
Posted: Fri Jul 16, 2010 5:45 am
Can you give more details of this driver? Is it from CCS? Or if you have found it on the web post a link to it.
The MAX6953 can drive up to 4 arrays of 5x7 LEDs. For 20 arrays you need 5 x MAX6953.
In the I2C communication bus every connected chip has a unique address. Because you are using several of the same chips you have to connect the chips in such a way that they all get a different address. See Table-3 in the datasheet. There are 16 possible addresses. Just choose 5 for your chips and then in your driver make sure to use these addresses.
