KnowMore
How to define data-table on on-chip EEPROM |
Posted: Fri Jul 16, 2010 2:55 am |
I want to define data-table on on-chip EEPROM, and this information will stay in hex file (so it's easy to program chip, and fix it if required).
Does anyone know how can I do?
Thank you! _________________ GOOD TODAY IS ENEMY OF BETTER TOMORROW |
Posted: Fri Jul 16, 2010 5:05 am |
#ROM
You need the 'programming' address of the EEPROM (varies with different chip families 0x2100 on the older PIC16 chips, 0xF00000 on the PIC18, etc. - look at the programming data sheet for this), then:
(on a PIC16)
#ROM 0x2100 = {1,2,3,4,5,6,7,8}
Will put 1 to 8, in the first 8 bytes of the EEPROM.
KnowMore
Posted: Fri Jul 16, 2010 10:24 am |
Ttelmah wrote: | #ROM
(on a PIC16)
Thank you very much! I can do now.
It's seem hard to find EEPROM address from device datasheet, programming specification . I looked for these address at Winpic800 software , and found 0x2100 for PIC12 and 16, 0x780000 for PIC18, 0x7FFC00 for dsPIC30. _________________ GOOD TODAY IS ENEMY OF BETTER TOMORROW |
KnowMore
Posted: Fri Jul 16, 2010 10:54 pm |
I've found that the best way to have EEPROM address of any chip is look in Device Table Editor of our IDE, in tab MCU Parts, middle table, Memory part. _________________ GOOD TODAY IS ENEMY OF BETTER TOMORROW |
MikeP
Posted: Sat Jul 17, 2010 2:15 am |
#ROM getenv( "EEPROM_ADDRESS" ) = {1,2,3,4,5,6,7,8}
This above will also work and will not need changing if you move to different chip. |
KnowMore
Posted: Sat Jul 17, 2010 10:10 am |
MikeP wrote: | Code: |
Oh! Thank you so much!
Coming here, I find that there are so many things which I don't know about in our IDE. _________________ GOOD TODAY IS ENEMY OF BETTER TOMORROW |
