18F2550 clock scaling
deperkin
PostPosted: Wed Jul 14, 2010 7:27 pm     Reply with quote
scaling question:
I have some code that is refurbished from a pic using 4MHz clock.
I now want to use the code for an 18F2550 that has an internal oscillator of 20MHz.
From my limited understanding this means that I am getting a 5MHz timing on the instructions.
How do I prescale this in order to get the instruction timing to 1MHz???
which would allow me to reuse my existing code (for a universal remote) without having to change much.
(i.e. the pic would be timing like a 4Mhz clock).
Thank all !
PostPosted: Wed Jul 14, 2010 7:38 pm     Reply with quote
Use the CCS functions, delay_us() and delay_ms(). If you set the
#use delay() to match your crystal, the compiler automatically
calculates the correct delay routines so that delay_ms(1) is always
the same 1 ms time.
deperkin
18f2550 delay
PostPosted: Wed Jul 14, 2010 7:41 pm     Reply with quote
For my previous code I had a delay(4000000), which worked fine. I can't recall what PIC this was with.
When I try the same code for my 18f2550 with a delay(4000000) I get garbage over the serial.
When I change it back to delay(20000000) then it works fine over the serial, but all of the timing seems to be wrong for the universal remote.
deperkin
18f2550 code - universal remote
PostPosted: Wed Jul 14, 2010 7:44 pm     Reply with quote
#include <18F2550.h>
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOLVP                  //
#FUSES NOPUT
#use delay(clock=4000000) //serial works with #use delay(clock=20000000)
#define RS232_XMIT   PIN_C6   //RS232 serial transmit
#define RS232_RCV    PIN_C7   //RS232 serial receive
#use rs232(baud=9600,xmit=RS232_XMIT,rcv=RS232_RCV,parity=N,bits=8,stream=COMP)
int counter,i,com,adr;
int16 buffer;
int16 cnt = 0;
#int_ext
void ext_isr(){
output_bit(PIN_C2, 1);
counter=0; //reset counter and buffer
buffer=0;
disable_interrupts(int_ext); //disable interrupts
while(!input(pin_b0)){ //wait for high level
  delay_us(15);
  ++counter; } //time how long has been low
  fprintf(COMP,"counter:%u\r\n",counter);
  if(counter>=15&&counter<=30){ //if from about 800 to 1000 us
     //do routines
     delay_us(200);
     for(i=0;i<13;i++){ //13 following bits
        if(input(pin_b0)){ //if the input high
          bit_set(buffer,0); //set the LSB and shift left
          buffer<<=1;}
        else //otherwise just shift
          buffer<<=1;
        delay_us(1740);  //wait for next bit
        buffer>>=1; //shift 1 right because of last reading
        com=buffer&0b00111111; //command is 6-bit long; ignore the rest
        buffer>>=6; //shift 6 right
        adr=buffer&0b00011111; //address is 5-bit long; ignore the rest
        //display on an LCD
        fprintf(COMP,"Address:%u  Command:%u\r\n",adr,com); //send bytes to the rs232
        delay_ms(150);
    } //wait
        //return(0); //return to main
main(){
  //output_bit(PIN_C2, 1);
  fprintf(COMP,"on... \n\n");
   while(1){
  ext_int_edge(H_TO_L);
  enable_interrupts(INT_EXT);
      cnt = cnt + 1;
      //fprintf(COMP,"cnt:%lu",cnt);
      output_bit(PIN_C2, 0);
      delay_ms(50);
deperkin
external clock
PostPosted: Wed Jul 14, 2010 8:20 pm     Reply with quote
I added an external clock (4MHz) and it works fine now... problem is that my code does not.
Can someone PLEASE PLEASE help me with this code?
I have a universal remote programmed with a Sony setting (TV).
I am not getting consistent address and command with the above code.
Also, I have to hold the buttons for a long time and many times in order to get any output.
Any suggestions???
Thank you all.
PostPosted: Wed Jul 14, 2010 9:12 pm     Reply with quote
Set this line in comment:
At 9600 baud it takes about 12ms to print this data causing your program to miss the first few data bits.
deperkin
working
PostPosted: Thu Jul 15, 2010 8:51 am     Reply with quote
Thanks for the advice!
I did get it working although not as consistent as I would like...
I need to buy an oscilloscope!
I changed the first delay to 20us, and changed the if statement:
  delay_us(20);
  ++counter; }
  if(counter<=75){
     //do routines
     delay_us(200);
Now it is working but not as consistent as I would hope.
Thanks again
