freshdesing
I2C communication between two 16F877A |
Posted: Wed Jul 14, 2010 6:01 am |
Hi, I connected two pics 16F877A using I2C. The master has four LEDs, when lit the first, sent as data "1" when lit the second led, sent as data "2" and so since four leds. The slave has an LCD screen that initially displays "waiting for data, and when it arrives (should) represents the data that has come on the LCD screen. The problem is that it works, it lights the first LED of the master and the slave not receive any data.. Both pic's has led to "status" that flashes every half second, and both work well, so do not stay in any loop or freeze. ... I would appreciate some extra help. The codes are:
MASTER´s code:
// RB7 --> ENTRADA ON/OFF
// RB6 --> ENTRADA ON/OFF
// RB5 --> ENTRADA ON/OFF
// RB4 --> ENTRADA ON/OFF
// RB0/INT -->
// RA0 --> LED STATUS
// RC7 -->
// RC6 -->
// RC5 -->
// RC4 --> SDA
// RC3 --> SCL
// RC2 -->
// RC1 -->
// RD0 --> OUT E
// RD1 --> OUT RS
// RD2 --> OUT RW
// RD3 -->
// RD4 --> OUT D4
// RD5 --> OUT D5
// RD6 --> OUT D6
// RD7 --> OUT D7
#include <16f877A.h> //pic a utilizar
#fuses XT,NOWDT,NOPROTECT,PUT,NOLVP,NOBROWNOUT //ordenes para el programador
#use delay (clock=4000000) //Fosc=4Mhz
#use i2c(MASTER, SDA=PIN_C4, SCL=PIN_C3,FAST,FORCE_HW)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#byte port_a = 0x05
#byte port_b = 0x06
#byte port_c = 0x07
#byte port_d = 0x08
#byte port_e = 0x09
int dato=0;
void i2c(int data)
i2c_start(); //condicion de inicio
i2c_write(0xa0); //direccion del esclavo con el que haremos la comunicacion
//A6 A5 A4 A2 A1 A0 R/W -> R/W = 0 escritura; 1 lectura
i2c_write(data); //enviamos dato
i2c_stop(); //finalizacion de la comunicacion
delay_ms(1000); //introducimos retardo para que no este constantemte escribiendo
#INT_TIMER1
void control_timer1(void)
output_bit(pin_a0,!input(pin_a0));
set_timer1(3036);
disable_interrupts(GLOBAL);
set_tris_a(0x00); // RA0 --> LED STATUS
// RA1 -->
// RA2 -->
// RA3 -->
// RA4 -->
// RA5 -->
port_b_pullups(false); // Resistencias de polarización del puerto B
set_tris_b(0xF0); // RB7 -->
// RB6 -->
// RB5 -->
// RB4 -->
// RB3 -->
// RB2 -->
// RB1 -->
// RB0 -->
set_tris_c(0x00); // RC0 -->
// RC1 -->
// RC2 -->
// RC3 --> SCL
// RC4 --> SDA
// RC5 -->
// RC6 -->
// RC7 -->
set_tris_d(0x00); // RD0 --> OUT E
output_d (0x00); // RD1 --> OUT RS
// RD2 --> OUT RW
// RD3 -->
// RD4 --> OUT D4
// RD5 --> OUT D5
// RD6 --> OUT D6
// RD7 --> OUT D7
setup_adc_ports(NO_ANALOGS);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
delay_ms(2000);
output_bit(pin_d0,1);
dato=0;
i2c(dato);
output_bit(pin_d0,0);
delay_ms(2000);
output_bit(pin_d1,1);
dato=1;
i2c (dato);
output_bit(pin_d1,0);
delay_ms(2000);
output_bit(pin_d2,1);
dato=2;
i2c(dato);
output_bit(pin_d2,0);
delay_ms(2000);
output_bit(pin_d3,1);
dato=3;
i2c(dato);
output_bit(pin_d3,0);
SLAVE´s code
// RD0 --> OUT LED
// RD1 --> OUT LED
// RD2 --> OUT LED
// RD3 --> OUT LED
// RC4 --> SDA
// RC3 --> SCL
#define use_portd_lcd TRUE
#include <lcd.c>
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
#byte port_a = 0x05
#byte port_b = 0x06
#byte port_c = 0x07
#byte port_d = 0x08
#byte port_e = 0x09
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3,ADDRESS=0xA0,FAST,FORCE_HW)
int dato=0;
BYTE incoming, state; // I2C vars
BYTE address, buffer[0x10]; // Address and Array of Bytes
#INT_SSP
void i2c_isr()
state = i2c_isr_state();
if(state < 0x80) //Master is sending data
if(state == 0)
incoming = i2c_read();
printf(LCD_PUTC, "\fEl dato recibido es:\n %u",incoming);
if(state == 1) //First received byte is address
address = incoming;
if(state == 2) //Second received byte is data
buffer[address] = incoming;
if(state == 0x80) //Master is requesting data
i2c_write (buffer[address]);
#INT_TIMER1
set_timer1(3036);
delay_ms(200); // power up delay
// RA1 -->
// RA2 -->
// RA3 -->
// RA4 -->
// RA5 -->
set_tris_b(0xF1);
set_tris_c(0xFF); // RC0 -->
// RC1 -->
// RC2 -->
// RC3 --> SCL
// RC4 --> SDA
// RC5 -->
// RC6 -->
// RC7 -->
//set_tris_d(0x00); // RD0 --> OUT LED
// RD1 --> OUT LED
// RD2 --> OUT LED
// RD3 --> OUT LED
// RD4 -->
// RD5 -->
// RD6 -->
// RD7 -->
setup_vref(FALSE);
setup_psp(PSP_DISABLED);
enable_interrupts(INT_SSP);
lcd_init(); //inicializa lcd
printf(LCD_PUTC, "\fEsperando dato..");
Thanks in advance.
Wayne_
Posted: Wed Jul 14, 2010 7:12 am |
First issue:-
int dato=0;
void i2c(int dato)
Do not do this in CCS or any compiler for that matter. CCS does not issue a warning to say you are using the same name for a local as you are for a global BUT there could and may (in my case, was) be problems.
Use different names for local vars.
Secondly, in your master code you are using standard_io so all those set_tris statements are irrelivant. |
freshdesing
Posted: Wed Jul 14, 2010 7:29 am |
Thanks, I am trying to use the standard_io, and I didn't remember to change to fast_io. I changed the local variable to "data", but the comunication don't works.
Anybody know if the code of comunication is correctly?
Thnaks. |
