rwskinner
Losing programming |
Posted: Fri Jul 09, 2010 3:13 pm |
Hello to all. I have an odd problem that I need to try and find a solution to. I have a 18F4550 (bunches of them) that randomly lose their program after a power cycle.
The panel can be up and operating fine, a technician goes out, powers down the panel, performs maintenance, powers back up, and the board with the pic 18F4550 is a dead. Reprogramming the flash with the program fixes it but we rather not have to do this !
I have several thousand 16F chips, and 18F series chips out running and I only ran across this a couple of times after a severe lightening storm, but never after a normal power cycle.
I was able to copy the flash, programming bits, and eeprom off one before I reprogrammed it and I'm about to start comparing bits to see where it's getting corrupt at.
Any tips what I might look for? |
asmallri
Joined: 12 Aug 2004 Posts: 1642 Location: Perth, Australia
Re: Losing programming |
Posted: Fri Jul 09, 2010 4:32 pm |
rwskinner wrote: | Hello to all. I have an odd problem that I need to try and find a solution to. I have a 18F4550 (bunches of them) that randomly lose their program after a power cycle.
Disable LVP and enable brownout _________________ Regards, Andrew
rwskinner
Posted: Fri Jul 09, 2010 4:38 pm |
I did have the CCS CDC Bootloader and just did away with it.
I also already had
NOLVP, BROWNOUT, and BORV20
I just set the following for Grins, Maybe it will help:
PROTECT
CPD
WRT
WRTD
WRTC
WRTB
EBTR
EBTRB
CPB
When I compared the hex I read from the device and the hex that I programmed the device with originally they were so different it wasn't even funny. |
asmallri
Posted: Fri Jul 09, 2010 4:44 pm |
rwskinner wrote: | I did have the CCS CDC Bootloader and just did away with it.
I also already had
PROTECT
CPD
WRT
WRTD
WRTC
WRTB
EBTR
EBTRB
CPB
If you are powering the PIC from +5volts then the BORV20 setting is too low. The PIC will already have crashed before it gets to this level. It should be more like 43 or whatever the value is for that specific PIC. _________________ Regards, Andrew
rwskinner
Posted: Fri Jul 09, 2010 4:46 pm |
This is what I have. Previously, Brown out voltage was 2.0 volts and all memory was unprotected.
NOW:
#FUSES HSPLL //High speed Osc (> 4mhz)
#FUSES USBDIV
#FUSES PLL5 //Divide By 5(48MHz oscillator input)
#FUSES CPUDIV1
#FUSES VREGEN //Voltage Regulator
#FUSES NOPBADEN //PortB pins are Digital
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PROTECT //Code protected from reading
#FUSES CPD // EE protection
#FUSES WRT //Program memory write protected
#FUSES WRTD //Data EEPROM write protected
#FUSES WRTC //configuration registers write protected
#FUSES WRTB //Boot block write protected
#FUSES EBTR //Memory protected from table reads
#FUSES EBTRB //Boot block protected from table reads
#FUSES CPB //Boot Block code protection
BEFORE:
#FUSES USBDIV
#FUSES CPUDIV1
#FUSES BORV43 //Brownout reset at 4.3V
rwskinner
Posted: Fri Jul 09, 2010 4:54 pm |
Ah, I overlooked the obvious, in the bootloader code, I did not have the fuses for Brownout and BOR set !!!
For Protection and Bootloader code, are these fuses ok?
PROTECT, NOCPD, NOWRT, NOWRTD, WRTB, WRTC, EBTR,EBTRB, CPB
This ought to protect everything but program memory and eeprom correct? |
rwskinner
Posted: Sat Jul 10, 2010 6:26 am |
Since I have your ear, where are the CCS Fuses for Brownout and Powerup Timer for the 18F26J50? I see the Deep Sleep Brownout DSBOR.
CONFIG3L in the datasheet, describes the config bits but it's all for Deep Sleep.
Richard |
Posted: Sat Jul 10, 2010 2:34 pm |
You do realise, that if you 'protect' the code, what you read back from a chip, will not resemble the hex file at all...
The 'verify' sequence with a chip with the protect fuse, is:
1) Write the chip without the protect fuse.
2) Verify against the hex file
3) Enable the protect fuse.
4) Read the data from the chip, and store it.
Then in future, program new chips, from the original hex file, but with the protect fuse set, and _verify_ against the file generated in step 4.
obdave
Posted: Sat Sep 25, 2010 3:07 pm |
Howdy folks, I found this topic via Google because I just had one of my devices lose its mind. Here are particulars:
* processor is PIC18F25J11 (part of the PIC18F46J11 family)
* I have a bootloader
* processor went into a weird mode and stayed there
* rebooting umpteen times didn't resolve the issue
* code failed to verify using MPLAB ICD2
* flashing in new code via ICD2 fixed the problem
Sounds like program memory corruption to me.
Here's the thing - in studying the data sheet for this PIC, there is no fuse for Brown Out Reset. BOR is always enabled on this device, as is the internal voltage regulator. This PIC does have a Deep Sleep BOR fuse. I don't use Deep Sleep mode but I have the fuse enabled anyway. I'm not sure if I've overlooked anything or whether this is enough to eliminate BOR as a cause for my memory corruption.
Any suggestions would be gratefully accepted.
Regards,
Dave |
Posted: Sun Sep 26, 2010 6:32 pm |
It could be any of the following, or several other things that are not listed:
Hardware:
1. A problem with your individual 18F25J11, or with the entire production
lot that your PIC is from.
2. A undiscovered errata with the silicon revision of your 18F25J11.
3. A problem with the design of your board, in the track layout,
component placement, and/or selection of component types or values.
Standard design practices may not have been followed.
4. A problem with a bad component on your individual board.
5. A misinterpretation of the PIC data sheet, so that the PIC on your
board is running outside of spec'ed design parameters. Or it could be
a misinterpretation of data sheets for other components on the board.
6. It could be a problem with the environment that the board operates
in, including electrical or temperature, etc.
Software:
7. It could be a problem with your version of the compiler. What is your
version ?
8. It could be a coding error done by you.
9. It could be the enabling of incorrect #fuses by you.
Here's a thread just on PCB track layout problems:
http://www.ccsinfo.com/forum/viewtopic.php?t=42775
The question is how to discover which of these things is causing the
problem. A lot of it can be done by swapping. Try using a similar PIC
from a "non-J" family. Try using a standard demo board from Microchip
as the platform, instead of your board. Try running the board in a
different environment. Try using a different CCS compiler version.
Try commenting out non-vital sections of your code. See if you still
get the problem.
Read my comments in this thread. See if you're doing any of those:
http://www.ccsinfo.com/forum/viewtopic.php?t=41964 |
assaad
Posted: Tue Sep 28, 2010 9:18 am |
Do you use flash write ? It can be a bug in your software. I have this issue 2 years ago, but it was a bug. |
